Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: TSL foam set up on wraith
Old 11-02-2011, 09:29 PM   #1
Default TSL foam set up on wraith
I searched for a couple days & couldn't find anything. I got tsl's for my wraith, want to know what foam set-ups are being used. Winter time is not good for the memory foams. Like to know what works best for yours. Thanks.
highhpcummins is offline   Reply With Quote
Old 11-03-2011, 09:13 AM   #2
Wondering the same thing. I am going to try the stock kit foams for the Ripsaws.
wrightcs77 is offline   Reply With Quote
Old 11-03-2011, 10:41 AM   #3
grab some CI novas foams 5.5in, im running soft inner soft outter up front and medium inner soft outter out back, if your truck is over 7.5 pounds go to a firm inner in the back and medium inner up front. also run the full width inner foam, dont narrow them with the TSL's
Rootar is offline   Reply With Quote
Old 11-03-2011, 10:53 AM   #4
I'm running the stock ones that come on the TSL's on mine right now and so far they work fine. Their a little soft for high speed turns but that's not what they were designed for so that's expected and my Wraith is pretty fast. If I were to change them I would go with some from CI.
Double Deuce Foams
dubAron is offline   Reply With Quote
