01-16-2012, 11:22 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| Axial wheel replacement hardware kits
Found some button head hardware that works with the 1.9 and 2.2(not XR10) axial wheels. They use cap head hardware that catches on rocks. These button head screws fit a bit tighter, and slide better on the rocks. Below is a link to where you can buy em. They are 2-56 x 3/8" CreationFab - Screw Kits Screws 2-56 x 3/8" Button Head Stainless Screw Set |
01-17-2012, 12:57 AM | #2 |
Rock Crawler Join Date: Jun 2011 Location: Las Vegas/671
| Re: Axial wheel replacement hardware kits
Just ordered a set, Thanks |
01-17-2012, 02:26 AM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: Waimanalo, Hawaii \m/
Any one no where I can find dummy screw for the axial beadlocks?
01-17-2012, 08:40 AM | #4 |
Rock Crawler Join Date: Apr 2009 Location: Pa
You can get the same screw from Mcmaster for under $6.50 per 100. Problem with the button head screws is the small hex (.050" on these) with very little "meat" to it so they strip easy. Soft stainless screws just make it worse.
01-17-2012, 10:09 AM | #5 |
McMaster sells a lower quality stainless. There are many people selling stainless out there. The place I order from has a much higher quality stainless. I was able to tighten these down pretty hard with my .050 Hudy driver, and they were solid. I do recommend someone invest in a decent .050 driver, and not try to use a little allen key for stuff like this. It will make your life so much easier. |
01-30-2012, 07:50 PM | #6 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Please enlighten us as to what this "higher quality" stainless is. As you can get both 18-8 and 316 stainless from them.
02-01-2012, 01:10 PM | #7 |
There is just different quality's from what I understand. The stuff I am getting from my current supplier seems harder than the stuff from my previous supplier. Much like a battery, just because it is labeled as something, doesn't necessarily mean it's true. I'm not saying McMaster's is bad, but have heard they strip easily. These button heads I got seem to be pretty nice, and I can tighten them pretty hard with my hudy driver, and they dont strip |
02-01-2012, 06:14 PM | #8 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
How short can you get them for all of us with MTHeads rings that need dummy screws?
02-02-2012, 12:24 AM | #10 | ||
| Re: Axial wheel replacement hardware kits Quote:
02-02-2012, 02:35 AM | #11 |
Quarry Creeper Join Date: Nov 2010 Location: grand rapid mich.
chris I have a nmih reg do i have to change al electrons inside to go lipo?
02-02-2012, 06:13 AM | #12 | |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
02-03-2012, 05:34 AM | #13 |
[QUOTE=Chris_The_Battery_Man;3541693]I can email my supplier and find out. any word on the shorter ones? |
02-03-2012, 09:54 AM | #14 |
Im in the middle of moving, so I haven't been able to email my supplier. Once my new office is finished, I will do so
02-13-2012, 05:08 PM | #15 |
Chris, did you get a chance to check on these?
02-14-2012, 05:21 PM | #16 |
Sorry, I havent. I just finished moving. I will email myself a reminder to check. I need to order more hardware anyhow
02-15-2012, 04:11 AM | #17 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
sorry, but i still have to call bs on the mcmaster thing, i use my mini impact to tighten things down all the time doing jig work and on my truck, and not a single stainless screw head has stripped. this is just with dynamite power tool tips, hell they ate an apex tip in a second the first time i tried that. using 3mm and 4-40. i don't know where you heard that they were strip happy, but from where i'm sitting, its pretty smelly.
02-15-2012, 05:45 AM | #18 | |
3mm and 4-40 have a much larger hex pocket for the tip. The 2-56's he's talking about are much different. Mcmaster sells good quaility stuff for sure, but I have had this problem with their 2-56 screws as well. | |
02-15-2012, 12:23 PM | #19 |
if i can tighten a 4-40 button head with an impact wrench then what is there to give me one shred of evidence that i'll strip out the same grade of screw with a hand driver.
02-15-2012, 12:36 PM | #20 |
| Re: Axial wheel replacement hardware kits |
Axial wheel replacement hardware kits - Similar Threads | ||||
Stainless Button head hardware kits for Axial/Losi wheels | Chris_The_Battery_Man | Vendors Tires and wheels | 3 | 08-06-2012 11:15 AM |
SCX replacement M3 black hardware from McMaster.common sizes? | spoo76 | Axial SCX-10 | 4 | 10-25-2011 08:40 PM |
Replacement Stock Hardware? | Fiveology | Axial SCX-10 | 1 | 11-26-2009 08:43 AM |
New LD Racing M3 Hardware kits | RPP Hobby | RPP Hobby | 2 | 06-10-2009 03:25 PM |
Hardware replacement | dano104 | Axial AX-10 Scorpion | 5 | 02-20-2009 07:01 PM |
