Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: current foam choice for white dot rovers
Old 02-14-2012, 10:01 AM   #1
Default current foam choice for white dot rovers
So with all the new foam options out there what does everyone seem to be running now adays? Currently im running the pro line dual stage with memory foams and it seems a little too bouncy/firm. My wheels are 1" wide and yes the wheels are vented. So what say you people?
001Hulk is offline   Reply With Quote
Old 02-14-2012, 11:25 AM   #2
Default Re: current foam choice for white dot rovers
crawler Innovation Firm/soft in front
Firm/medium in rear
but I need to try the new foam
dude26 is offline   Reply With Quote
Old 02-14-2012, 12:17 PM   #3
I've heard nothing but good things about the Crawler Innovations foams. Right now I'm running the VP adjustable foams all around in my rovers and have had great luck with it.
jsowens is offline   Reply With Quote
Old 02-14-2012, 12:19 PM   #4
Same as dude 26, but I am running Sedonas in the front and Rovers in the rear.. both white dot.
Going to switch to firm/medium all the way around to see if the sedonas like it a little more.
The rovers work great with the medium out back.
Remember, your rig's weight plays a big part in what foams you need.
bigstu is offline   Reply With Quote
Old 02-14-2012, 12:20 PM   #5
CI foams do work the best. But the stocks foams are also proven to work well if you are on a budget.
jcboof is offline   Reply With Quote
Old 02-14-2012, 12:23 PM   #6
Thanks guys!! I currently have a set of the CI foams like dude but in a set of sedonas. Looks like im robbing those tonight!! Seems to make sense, the memory foams will fill the slightly taller sedonas and the softer CI's should eleminate some of the bounce im encountering up in the front with the rovers.
