02-22-2012, 04:14 PM | #1 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Internal Beadlock Wheels
Hello, new here and need your help. Would someone explain how an internal beadlock wheel works. Is there a screw type bead lock or is this another term for a wheel that you glue the tire to. Thanks
02-22-2012, 06:10 PM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: strawtown
| Re: Internal Beadlock Wheels
internal beadlock wheels are a 3 piece design with a front a back and an internal sleeve that locks the tire in place. regular beadlock wheels have a rim with external rings that clamp the tire in place. rims where you glue the tire in place are also called nonbeadlocks. hope this helps |
02-22-2012, 06:18 PM | #3 |
Here's an example of one. Notice the ring inside just floats inside the beads of each side of the tire. The outer rings lock together, clamping down on the ring inside: |
02-22-2012, 09:13 PM | #4 |
Muddawg, thank you for the explanation. With the photo that C*H*U*D provided I now understand. Thanks guys
02-24-2012, 03:45 PM | #5 |
I joined the Band! Join Date: Dec 2010 Location: Usa
That looks like more of a pain in the ass to swap tires than beadlocks.
