03-12-2018, 11:16 AM | #41 | |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
| Re: anyone else run thier tires with no foams? Quote:
I do . Love it. No more wet foams is a good thing. And aired tires work better than those closed cell foams. Not to mention its scale. Will be competing at the nationals this year with air tires. I will say that foams are better overall. I just absolutely can not stand wet foams. Much rather have air tires. Or better yet a combination of both Last edited by holycaveman; 03-12-2018 at 11:19 AM. | |
03-12-2018, 11:22 AM | #42 |
I was at a winter comp several years back. The 2.2pro winner had sealed tires. He ran negative pressure with sealed tires. He simply walked some sections where the rest of us just slid. His tires looked funny having flat spots, LOL, but it worked.
03-12-2018, 12:51 PM | #43 |
| Re: anyone else run thier tires with no foams? I would like to see that on video. Negative pressure, aka vacuum? I don't see how that would work at all.
03-12-2018, 01:21 PM | #44 |
| Re: anyone else run thier tires with no foams? |
03-12-2018, 01:22 PM | #45 |
But I will tell you how it worked for me this year running sealed air tires. |
03-12-2018, 03:48 PM | #46 |
Quarry Creeper Join Date: Jul 2013 Location: PA
I run non vented tires, on beadlocks with foams... air/ foam mix!
03-12-2018, 04:24 PM | #47 |
This needs to be moved to the noobie section.
03-17-2018, 10:52 AM | #48 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
03-17-2018, 06:02 PM | #49 |
One problem with moving it to the newbie section is that more people without the experience to know better will try it and have shitty results, causing them to second-guess continuing with the hobby! |
03-18-2018, 01:55 AM | #50 |
Foams don't cure bad driving. And there are advantages to air. Depends on what you are doing. If you are comp crawling then who cares. You run foams. If you run scale, it works pretty well in some situations. Not to mention SCALE. It's a valid question to anyone with experience.
03-18-2018, 05:17 AM | #51 | |
But it makes perfect sense that the SCALE term is reinforced. SCALE is anti performance so it makes 100% perfect sense why it'd be preferred by a scaler. | |
03-18-2018, 07:23 AM | #52 | |
03-18-2018, 07:54 AM | #53 |
03-18-2018, 08:08 AM | #54 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
I wish there was a disagree button... I’ve never changed foams before, but I’ll take a water logged foam over a cut up rc tire all day. Last edited by Alexander_0_1; 03-18-2018 at 08:15 AM. |
03-18-2018, 10:15 AM | #55 |
03-18-2018, 11:32 AM | #56 |
03-18-2018, 01:02 PM | #57 |
| Re: anyone else run thier tires with no foams? getting old and bitter in a hobby doesn't help anyone. And I am far from a sorcca fan
03-18-2018, 01:25 PM | #58 | |
Realistic is great, I'm fully in support of having rigs that look like something. But being required to handicap a rig is idiocy. | |
03-18-2018, 01:36 PM | #59 | |
06-11-2018, 09:20 PM | #60 |
I know this thread is older but, I think its important to realize not all RC tires or rigs are the same and your miles may vary. My brother has some older tires on his wraith that have quite firm sidewalls that were perfectly fine if not too stiff with no foams and vented wheels. My stock bomber BFG Baja's I liked after I cut off the outer 50% of the foam off. It didn't side hill great so I avoided putting myself in that situation, But It would drive up slopes many other people would just slide on. And there is always a trade off, you will get more surface area gripping the surface at lower pressures which "can" translate to more traction and lower center of gravity This can also easily cause balling up of your tires under load, poor side hill ability, unpredictable behavior when you jump on the throttle, and putting your center diff even closer to those pesky rocks. It is much easier to manage these behaviors with foams, and I would highly recommend a 2 stage foam with a stiffer inner core and the softer outer rim. Air Is less predictable and has vastly different effects with different tires, a tire with a thicker sidewall would handle it better. If you have vented wheels you can try taping over the vent to seal them off. As far as negative pressure. With a stiffer tire when you mount the tire just before you seal it, dimple in part of your tire with your finger, half an in or quarter of an inch. They don't mean a complete vacuum, it doesn't take much. This would help a more rigid tire to flex more. {edit} This also seems like a good place to mention, some tire foams break down faster then others. So before you go cutting into them, try breaking them for a few hours a week, for a few weeks. {/edit} I swear the battles I see on the internet, this vs that are way too intense... So to answer the original question is there any reason not to do take the foams out of your tire? Yes, it takes time and effort. Should you do it? Yes, because doing stuff like this is how you lean, and its FREE! Now you know what to look for when you try it and decide for yourself weather or not you like it more with your rig, your driving style and the environment you drive in. If you like people telling you what you just saw happen isn't possible, you could even share your results on the interwebs! Last edited by Voodoobrew; 06-11-2018 at 10:13 PM. |
anyone else run thier tires with no foams? - Similar Threads | ||||
help....stock tires cut foams or no foams? | Jcplante | Redcat Crawlers | 8 | 08-22-2011 07:32 AM |
has anyone removed thier tires? | liveforocks | Axial Wraith | 3 | 06-26-2011 07:07 AM |
foams? Should all 4 tires and rims have foams? | riz | Newbie General | 5 | 02-04-2010 10:49 PM |
how do you get BB's in your tires and run foams?? | madmax22 | Tires and Wheels | 30 | 07-18-2009 09:14 PM |
who cleans thier tires? | JohnRobHolmes | Tires and Wheels | 10 | 08-09-2005 11:06 PM |
