Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: 2.2 VP SLW V-2 mounting help !!
Old 10-14-2014, 10:12 PM   #1
Default 2.2 VP SLW V-2 mounting help !!
I'm trying to mount a set of BFG Krawlers to these wheels with CI deuces wild foams and they mount fairly easily but the bead slips out with a little pull of the tire. I mounted again and a few hours later the beads slipped out again without ever touching them. This is happening on all 4 wheels. Other then gluing is there any tricks to mounting tires to these wheels?
crawler105 is offline   Reply With Quote
Old 10-16-2014, 06:14 PM   #2
Default Re: 2.2 VP SLW V-2 mounting help !!
no tricks. How is it slipping out without pulling it. when you tighten it down are you tightening it so the ring and wheel are metal on metal on the inside where you can see?
lawhorn_derrick is offline   Reply With Quote
Old 10-16-2014, 11:25 PM   #3
Yea metal on metal all the way around. I ended shaving a hair off the deuces wild side walls and all is good now. The foams was pulling the side wall so tight it was pulling itself out.
Old 10-22-2014, 07:37 PM   #4
I have the slw V2's running rok lox, got the tall foams and still had to cut them apart and cut 1 entire rib section out
BigSid00 is offline   Reply With Quote
Old 10-23-2014, 02:45 AM   #5
What about washing the tires to get the mold release off and make them stickier?
show&go is offline   Reply With Quote
2.2 VP SLW V-2 mounting help !! - Similar Threads
Vanquish SLW wheel hub wheel mounting screws? chevyfan3 Tires and Wheels 6 05-16-2013 04:43 PM
Mounting Chisels With Memory Foam On VP SLW V3's Dini Tires and Wheels 12 07-10-2012 03:03 AM
Mounting SLW hub on xr10 wheel dogzpolo Tires and Wheels 6 02-18-2012 09:48 AM
AX Link and shock mounting, Vs Berg mounting locations. BEELZEBOB Axial AX-10 Scorpion 4 06-09-2009 04:04 PM
