04-23-2012, 04:15 PM | #1 |
| recommendations for stiff foams
I'm needing some guidance for some super stiff foams, I know that this is the opposite of what most folks want! My 1/6th scale Willys has no problem completely crushing the stock black foams that came with the RC4WD RokLox. From everything that I could find in here, it seems like are the stiffest stock foams known to mankind, but I need more! Thanks for any ideas. |
04-23-2012, 05:22 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: recommendations for stiff foams
Have you thought about possibly doing a cut and shut to some 1/5 scale foams?
04-23-2012, 09:02 PM | #3 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
Idk what those come with but ive seen ppl stuff multiple foams in a tire to make them stiff. Also f400s are usually a pretty stiff foam.
04-23-2012, 10:49 PM | #4 |
F400 ftw
04-23-2012, 11:02 PM | #5 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Crawler Innovations closed cell inners with firm outers? I'd ask Eddie what he thinks, but I'd say some 5.5" or 6" inners would be the deal.
04-23-2012, 11:57 PM | #6 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
Very interested in this as well, I'm running r35 ripsaws with standard foams on axial 2.2s on my 1/6 willy's weighing 12 pounds and they need help, mainly on turns.
04-24-2012, 02:41 PM | #7 | |
| Re: recommendations for stiff foams Quote:
04-24-2012, 04:28 PM | #8 |
It will hold any 2.2 tre as far as I know, but seriously, have you thought of doing a cut and shut to a 1/5 scale foam?
04-25-2012, 02:27 PM | #9 |
| Re: recommendations for stiff foams |
04-27-2012, 08:26 PM | #10 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
The crawler InNovations new closed cell are awesome. I have had several different set made up recently for all my scalers. If you give him a weight and he can set you up. I just had a set of the above mentioned with outer firms for a heavy weight scaler I'm planning. For a rig that heavy you may end up just running a single stage large closed cell foam. He runs a single stage closed cell in his 6x6 that is very heavy. All in all the new foams are a must for the scale crowd of all tire sizes. Gives a soft enough outer for the tire to do work, but has a nice firm sidewall for support and side hilling. I have converted all my tires to the new system. Thanks Clay Carter Fab & Machine |
04-28-2012, 10:56 AM | #11 | |
04-28-2012, 02:23 PM | #12 |
Carpet pad is about 8lb/ft3 iirc some closed cell gym foam stuff are about 3-4lb/ft3. If you're into experimenting that is. Eddie at CI will set you up as others have recommended with a for sure setup.
recommendations for stiff foams - Similar Threads | ||||
How to get stiff | codydray | Paint and Body | 7 | 11-19-2009 01:28 AM |
