Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Better tire
Old 12-28-2004, 09:43 AM   #1
Default Better tire
What would be a better tire for crawling, Giant tracs on slightly narrowed rims, or jumbo swamp dawgs on standard size mazz rims?
mrwonderful is offline   Reply With Quote
Old 12-28-2004, 10:01 AM   #2
Default Re: Better tire
giant tracs
mike is offline   Reply With Quote
Old 12-28-2004, 10:50 AM   #3
PapaGriz Yo
Grizzly4x4's Avatar
Giant Tracs are tough to beat but Jumbo Swamps are the only tire I have used that are even close.
My rig did really well at the Utah and Colorado comps with JSD's.
Grizzly4x4 is offline   Reply With Quote
Old 12-28-2004, 12:49 PM   #4
I know that Pinchy mentioned that the Krocks are his second or third favorite tire. I would agree that in warm weather, the Krock is very hard to beat. You do have to do some major trimming to make them work but they are a much better tire than originally thought.
I love the LST's too. Great all around tire.
So much of these conversations on tires are missing a major factor: Weight.
Every tire will perform differently on different trucks. Clods vs. shafties is a perfect example. Clods typically weigh a lot less than a shafty which will change things when reviewing a tire. Keep that in mind. Also, the way the traction works between a shafty and a clod will have an affect on tire performance. I haven't used Swamp Dogs on my Clod but when using them on my shafty trucks, I only thought of them as a marginally good tire. But I would believe Griz in saying that they perform excellent on a clod. I have seen the SD in action with the Swampers and it did seem to do very, very well.
DirkDigler is offline   Reply With Quote
Old 12-28-2004, 02:41 PM   #5
Ok, so what about LST's on a clod, are teh better than giant tracs? I would like to get a tire that has amazing traction, and a pretty big. The GT get the traction, but are a little too small IMO.
Old 12-28-2004, 03:03 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
Like Digs said, there are alot of factors to consider.
LST's kick ass too, they werked real well on TSD. Different tires perform better in different terrains and situations.
When I ran my LST's in Utah, they got me up some obstacles that the guys with JSD's and Giant Tracs struggled with. And the LST's struggled on one section that the GT's got up.
My JSD's got me up some obstacles that the LST's couldn't when I was at Crawlstock.
No tire is perfect in EVERY situation but LST's, JSD's, GT's all werk great in most situations. KROCK's, Savage GTs, MGT's, and others can work well in the right situations.
Old 12-28-2004, 03:31 PM   #7
RIP Buster
badger's Avatar
Quit beating around the bush Griz, and answer the F'ing question!
badger is offline   Reply With Quote
Old 12-28-2004, 03:33 PM   #8
PapaGriz Yo
Grizzly4x4's Avatar
Uhhhhhh, what question? :?
:P
Old 12-28-2004, 05:55 PM   #9
Est. 2003
PinchFlat's Avatar
no.
PinchFlat is offline   Reply With Quote
Old 12-28-2004, 07:54 PM   #10
heres my 2 cents. i ran LSTs for a half hour and was not impressed, the rubber was to bouncy. when your watching other trucks at a comp you need to take into account the driver and his radio, because that will make a difference in the trucks ability which will sway your assesment in a tires ability. the giant tracs have been the most impressive but its not the tread pattern its the Proline M2 compound. Im not sure that grizz has driven the giant tracs that much and i respect him for that he just knows how to drive and if he had a set i dont think i would compete if i didnt have two full sets of giant tracks still in package i would get some proline moabs and cut and shut them. once you have a good compound you can design your tread.
jtothec is offline   Reply With Quote
Old 12-29-2004, 09:29 AM   #11
Guest
Posts: n/a
Thanks for your help. I think im just gonna stick with the GT's.
Old 12-29-2004, 10:15 AM   #12
are the Moabs made in the M2 compound?
Old 12-29-2004, 10:19 AM   #13
there are just too many factors in picking the ultimate tire.
Foams or no foams
vehicle weight
shaft or clod
driver or driver style
radio
pnuematic, semi pnuematic, etc
tread pattern cut or not
narrowed or not
weather / hot or cold
terrain, rocky, smooth, sandy, snow, rain, etc
Just use what works for you. Personally....I own most of the tires made and I just switch to what works best for the terrain I'm on that particular day.
