Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: advice on 2.2 ripsaw tires on 1" aluminum wheel
Old 09-21-2012, 02:51 PM   #1
Default advice on 2.2 ripsaw tires on 1" aluminum wheel
hey folks
you that have a lot more experience on crawling tires and wheels
how do you think that would look some DNA wheels or vanquish that normally are 1" / 1.2" with rings on stock r35 2.2 ripsaw for the wraith?
too side ballooning, decent fit, right fir or perfect fit?
any one have pics of 2.1 - 2" width tires on 1" wheels?
Steelfish is online now   Reply With Quote
Old 09-21-2012, 03:21 PM   #2
Jus
Default Re: advice on 2.2 ripsaw tires on 1" aluminum wheel
In my experience, the Ripsaws were much happier on a slightly wider wheel.. I tried mine first on 1" VP SLW's but didn't like it at all... Now have them on Gear Head ez-loc rims that are 1.3 IIRC and they work much better.. Sidewalls are more parallel between the bead and edge of tread instead of being sucked in by the rim. I'm certain there are folks who feel the opposite and a different way works better for them and they wouldn't be wrong.. I've just stated what works for me.
Jus is offline   Reply With Quote
Old 09-21-2012, 07:08 PM   #3
I have mine on 1" wheels and like it that way
frdtrkguy is offline   Reply With Quote
Old 09-21-2012, 07:42 PM   #4
I run both my sets of ripsaws on 1" wheels. They are just fine.
chicklet is offline   Reply With Quote
Old 09-21-2012, 08:21 PM   #5
Stock ripsaws are NOT the r35 compound, stock ripsaws need to be cut and or siped to allow the stock medium compound rubber to flex a lil more. Usually wide wheels dont allow as much flex of the rubber, so be careful how wide of a wheel you use. If you bought a set of ripsaws from a hs or online hs then those are the r35's, A little better specification would help. I personally dont think the r35's need to be cut, at most you could sipe the r35's but I wouldn't even do that. BTW I ran the ripsaws on a 1" wide wheel as well and I thought they were great.
taco08jk is offline   Reply With Quote
Old 09-22-2012, 01:26 AM   #6
Cool thanks guys a pic will help a lot to see them but I will trust in you on this,
Sorry if I didnt clarify this since the beggining but mines are the ones that come with the kit so they're r35 compound, are really sticky and soft as you can check in the axial website.
Old 09-22-2012, 01:30 AM   #7
Originally Posted by Jus View Post
I tried mine first on 1" VP SLW's but didn't like it at all... Now have them on Gear Head ez-loc rims that are 1.3 IIRC .
What is IIRC? Width without rings?
Old 09-22-2012, 03:06 PM   #8
Jus
Internet laziness for "if I remember correctly"
Old 09-22-2012, 05:04 PM   #9
Here ya go. 1" Vanquish wheels... R35 tires. Personally, I love the combo.
Full_Throttle is offline   Reply With Quote
Old 09-24-2012, 11:16 AM   #10
yep, your were right, they look great
thanks for the pics
Old 09-24-2012, 12:39 PM   #11
Jus
RPP lists these rims as 1.54" wide.
Old 09-26-2012, 03:04 PM   #12
wow.. those last wheels looks great.. loving the chrome offset and black interior
advice on 2.2 ripsaw tires on 1" aluminum wheel - Similar Threads
aluminum 1.9" wheel/tire combo fred0000 Tires and Wheels 11 10-09-2010 03:10 PM
