Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Should i cut or leave wide?
Old 01-02-2005, 01:35 AM   #1
kickback_crawler's Avatar
Default Should i cut or leave wide?
Can some of you let me know what you think Should i cut the rims to make them narrow or should i just leave them wide.
kickback_crawler is offline   Reply With Quote
Old 01-02-2005, 02:07 AM   #2
Default Re: Should i cut or leave wide?
IMO leave them wide I think it fits the truck better.
skyjacker_rc_club is offline   Reply With Quote
Old 01-02-2005, 02:20 AM   #3
RIP Buster
badger's Avatar
I think you should narrow them. They stick to pretty far out of the wheel wells.
badger is offline   Reply With Quote
Old 01-02-2005, 02:45 AM   #4
Here's a Masher 2k on a slightly narrowed rim
I've got a set of swamp dawgs coming and I'll probably narrow the rims but I"m waiting to get them before I cut the rims. If you cut the rim cut the inside bead off first and try it. It won't make you lose any overall width but will change how the tires sit on the rim.
rckjeep is offline   Reply With Quote
