Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Foam.......or not to foam................1STposting was lost
Old 01-15-2005, 12:21 AM   #1
Default Foam.......or not to foam................1STposting was lost
here goes again i have a set of Pro-Line Moabs on TXT-1 Weld Outback wheels should i run the foams or no foams at all?????? The tires are pretty stiff with the foams in in my other posting someone had said to ut the thickness of the foam in half
Just looking for some input my last posting was here but is gone now
so here is another!!
Thanks
John
twisted84toyota is offline   Reply With Quote
Old 01-15-2005, 03:23 AM   #2
It's a setup!
jason's Avatar
Default Re: Foam.......or not to foam................1STposting was
FYI, when I first put on my moabs I was messing with different things to see what might work best. The only way I drove it was with no foam.
1. Stock foams, were way too much, and made the tires hard.
2. Stock emaxx foams were way smaller and let the tires flex way more than stock moab foams.
3. I chose to use no foams, but may try to run the emaxx foams and see how that works.
jason is offline   Reply With Quote
Old 01-15-2005, 08:57 PM   #3
thx for the help i will try the max foams first
Old 01-16-2005, 10:03 PM   #4
well i have taken the wheels apart from the wheels and the maxx foams did not have enough sidewall stiffness for the type of crawling how did you cut the foams down the only thing i came up with was to use a breakable razorknife...............................any more thoughts?
Old 02-06-2005, 06:04 PM   #5
a breakable razor knife would porbably work quite well. not sure exactly how youd do it but with a razor knife you could do in half the time. keep us updated(or atleast me) cause i just got the moabs but no rims yet so i can do what works best before i get my rims
gooba is offline   Reply With Quote
Old 02-06-2005, 06:56 PM   #6
06 Super National Champ
JasonInAugusta's Avatar
band saw
JasonInAugusta is offline   Reply With Quote
Old 02-06-2005, 07:28 PM   #7
I just bought some moabs and outlaw 40's for SR5Dave. I narrowed the rims about 3/4", and I am running no foam. These things have great grip!
kwj48 is offline   Reply With Quote
