05-27-2013, 08:56 PM | #1 |
Newbie Join Date: May 2013 Location: Montreal
| Does 1.9 wheel wideners exist? Not talking about spacers |
05-28-2013, 09:48 AM | #2 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Re: Does 1.9 wheel wideners exist? Not talking about spacers
ive looked around, and the only answer i came up with was to have a set custom milled by a vendor on here, either out of aluminum or delrin, i like the look as well just slightly less than your pic,
05-28-2013, 10:12 AM | #3 |
eddie at Crawler innovations makes them for VP wheels. Crawler Innovations Bead Lock wideners for VP wheels but they are for 2.2 another option would be bolting/glueing/fiberglassing two axial plastic 1.9s together. Last edited by STANG KILLA SS; 05-28-2013 at 10:14 AM. |
05-28-2013, 06:28 PM | #4 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Nobody listens to the people who actually use the products. I have told manufacturers to make wider wheels and that wider wheels make the current and available market tires perform better. But nobody listens. As long as the masses buy parts that don't perform but because it looks good, nothing will change. I'd love to buy some 1" or wider 1.9 wheels. I'd love to buy some 1.35" and wider bead locks.
05-28-2013, 06:35 PM | #5 | |
Sent from Outerspace Using My iFreeze Ray Gun | |
05-28-2013, 06:49 PM | #6 | |
| Re: Does 1.9 wheel wideners exist? Not talking about spacers Quote:
VP uses 3 piece design for all the scale wheels, so it would be more involved than the simple 1/4" widener I made for the SLW. Most people do not see the added cost of a widener as affordable. | |
05-28-2013, 06:56 PM | #7 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
| Re: Does 1.9 wheel wideners exist? Not talking about spacers |
05-28-2013, 08:41 PM | #8 | |
| Re: Does 1.9 wheel wideners exist? Not talking about spacers Quote: I can take care of you for foams. I recommend the 4.50" Lil' Nova Foams for the 1.9 Rock Beasts. Here is a link: Lil' Nova 1.9 Dual Stage 4.50T Foam Pair (2) If you place an order, in the customer notes tell me the width of your wheels and I will set you up with a wider set of foams. Beautiful yota | |
05-28-2013, 08:46 PM | #9 | |
Sent from Outerspace Using My iFreeze Ray Gun Last edited by Big Tex; 05-28-2013 at 08:51 PM. | |
05-28-2013, 09:51 PM | #10 |
Quarry Creeper Join Date: Feb 2010 Location: melbourne
It's simple bolt two rims together then cut out the inner ring of the outer rim. Once you do that it will bolt up like normal but with a really big lip.
05-29-2013, 01:36 PM | #11 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Or take a wheel and split it, then glue a piece of PVC or ABS pipe in between to make whatever width you want.
05-29-2013, 01:50 PM | #12 |
It would be nice if someone made a wide 1.9 wheels so you could play with custom tires like these: 1.9 cut n shut panther cobras with HB rover 1.9 sidewalls 2 1/8" wide Compared to a Trep & Rock Beast . Sent from my iPhone using Tapatalk |
05-29-2013, 02:15 PM | #13 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
05-29-2013, 09:02 PM | #14 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
Make them yourself: Cut here to make the ring that will be glued to another wheel: Take off paint of "donor" wheel: Join together with CA: These are 1 5/8" wide: Same wheels with Pitbulls: Full, double-wide with reduced 2.2 TSL's: Last edited by 808DA6; 05-29-2013 at 09:05 PM. |
05-30-2013, 09:52 AM | #15 |
Exactly, I wouldn't mind paying more for wider wheels. I don't understand why nobody have done it yet or sales a wheel with different width option..
Does 1.9 wheel wideners exist? Not talking about spacers - Similar Threads | ||||
Any Vendors, wheel spacers, wideners for TLT | Rat1 | Tamiya TLT Crawlers | 5 | 02-10-2007 08:31 AM |
Wideners/Spacers for tlt axles?? | NorCal 2500HD | Tires and Wheels | 7 | 01-01-2006 08:59 PM |
