06-03-2013, 06:03 PM | #1 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
| Fitment Issues
Hey guys I just bought pitbull 2 tires along with RC4wd steelies wheels. These damn tires will not stay on the rims and I'm not sure what I can do. I'm thinking right now I need to return this stuff. Anyone have any insight on this topic? Thanks. Shayn
06-03-2013, 06:24 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
Have you tried using 3-4 longer starter screws? Sometimes that helps them to stay on the bead. |
06-03-2013, 07:17 PM | #3 |
| Re: Fitment Issues
I can get it started fine its once I start tightening them down the bead doesn't want to stay in. I bought the pit bull foams as well. They were quite big on the sides. It might help to trim the sides a little but really that shouldn't be needed
06-03-2013, 07:29 PM | #4 |
| Re: Fitment Issues
Just a quick update. I can get the tires to bead fine without the foams in. Not sure if I'm going to go this route or try and cut the foams down to make it easier to bead the tires. What do y'all think?
06-04-2013, 06:18 AM | #5 |
| Re: Fitment Issues
I usually bevel the inside edge of the foam at about 45 degrees and that helps a ton. Try also taking a mason jar ring and use it to squish the tire and foam while you tighten the screws. Then the foam will puff back up when you lift it up.
06-04-2013, 11:40 AM | #6 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Fitment Issues
I know that other brand tires have had fitment issues on RC4WD steel wheels, the Pro-Line TSL's for example wont work. RC4WD design their wheel to fit their tires, sometimes a custom inner ring has to be used to get the tire to fit properly. |
Fitment Issues - Similar Threads | ||||
Proline cherokee body fitment issues on trail honcho | XJrob | Axial SCX-10 | 9 | 12-31-2012 01:53 PM |
Axle Fitment | JUGGARNAUT | Axial Wraith | 8 | 12-27-2011 07:07 AM |
Vanquish fitment issues | scrotsbiz | Axial Wraith | 15 | 11-21-2011 08:36 PM |
VXL fitment | CarLo | Axial SCX-10 | 3 | 07-23-2010 06:11 PM |
Dig fitment | Kanine38 | General Crawlers | 10 | 05-19-2010 05:08 AM |
