Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Softer tires! would this work?
Old 05-12-2004, 03:38 PM   #1
Default Softer tires! would this work?
I have some tire compound from my touring car days. Does that compound soften tires or just make them sticky temporarily.
thanks guys
rcracer is offline   Reply With Quote
Old 05-12-2004, 05:05 PM   #2
Default Re: Softer tires! would this work?
It's probobly the same st of the guys use at the dragstrip, if it is, it just makes them temporarily sticky. The only way to make the actual tire softer is a different compound or pre-heat them.
skoolbus is offline   Reply With Quote
Old 05-12-2004, 05:46 PM   #3
to make them softer before you go out take them and give them a god coat of wd 40 and wipe it off after around 30 minutes and then if you want them even softer take motor spray cover the tire and then light it we do it for the buggies all the time
firstumustcrawl is offline   Reply With Quote
Old 05-12-2004, 06:35 PM   #4
I have been carving up another set of tires...
Since my GF used all my rotary sanding deals for something she was doing; I resorted to the grinding stone knowing it'd make a bit more heat and smoke... When the tires get heated up to hot enough to start melting, its like it devulcanizes them, and they become insanely sticky. The effect has lasted a day and a half now, so it might even be permanent. If not I imagine Ill just bring a propane torch to comps to warm up my tires suuuuuper sticky! give it a try, get going until they're just about on fire then pat it out with a cloth or something
SR5Dave is offline   Reply With Quote
Old 05-12-2004, 09:08 PM   #5
you can use paragon traction compound it works very good on touring cars and will leave the tires sticky even after a day of 40mph tire ripping action. i have never tryed it on a crawler
skyjacker_rc_club is offline   Reply With Quote
