| | #1 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| I posted sneak peak of these in WannaBe's thread for Moab's and I want to go into more detail w/out hi-jacking his thread. After reading his Ultimate Tire Foams thread I found some egg crate foam (I think that's what it's called). It already has similar contour to what he was describing. I'm going to try custom cut foams using this and see if it works. I also bought a hand full of o-rings w/ about 3 5/8" I.D. and about 1/4" thick. I'm using these as temp beadlocks, sort of, you can use these on rim to play w/ different tire widths. I'll get better pics of tires, foams and o-rings up later today hopefully. I wanted to throw these ideas out there. OK on to pics. I narrowed rims on axle side only, took out roughly 3/4". I cut axle side bead seat off , cut rim down to webbing on backside. Then sanded the two on flat surface before glueing back together. So far it is plenty strong. Rim width 2 5/8" Tire diameter 6 5/8" ![]() ![]() ![]() Last edited by BENDER; 01-30-2005 at 12:32 PM. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jul 2004 Location: Rexburg
| Looks Great! How well do they work? |
| | #3 | |
| | #4 |
| Here are a few more pics. This is the profile I'm going to run. ![]() You can see seam from narrowing, holes I drilled behind webs, and how much more I need to narrow rims to stay w/ that profile. Basically I'm going to cut inner part of rim off up to backside of webbing. But I'm still not sure need more test runs to tell. ![]() Pics of foam I'm going to try out in comparison w/ piece of stock foam I cut off. O-ring works ok for checking tire widths, I had them tucked between tire bead and bead seat on rim. They worked good for testing I never tack glued tires or o-rings and I was able to test drive in rocks w/out rim spinning inside tires ![]() Here's my rig next to my buddies brand new Super Clod. He's thinking about buying Gecko 2 LWB chassis, I'm pushing him in that direction anyway. It's his first real r/c. Gives a rough comparison in tire size. Last edited by BENDER; 01-24-2005 at 01:07 AM. |
| | #5 | |
| | #6 |
| | #7 |
| Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| Looks good! If my current wheel/tire combo doesn't work out, I may have to jump on the "40's" bandwagon and try 'em out. |
| | #8 |
| Well, they're all glued up and working awesome. The egg crate foam was too soft for my rig, it weighs almost 10lbs, but it might work in a clod or small scaler w/ thin skinned tire. I did let profile out a little from earlier pics. I ended up w/ narrowed stock foams, cut down about an inch. I'll get a couple more pics of finish set-up soon. |
| | #9 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| I caint believe how nicely the lugs pulled over to the sidewall. They look like they should be awesome Bender. I was at the westminster HTown and almost bought a set of them, I think I'll try my other tire idea first though. Great job, caint wait to see them in action. |
| | #10 |
| Thanks Grizz, that's where I bought these. Suppose to hook up w/ Dirk and them for "lunch" crawls, I'm anxious to see how they compare to his Moabs. |
| | #11 |
| Lemme know when you guys go. I werk off of 120th and Grant so I dont think I'm too far away. Sometimes I have extra time for lunch. |
| | #12 |
| Sweet, Dirk mentioned he might have time this week. But, no set plans yet. |
| | #13 |
| Now that I've had a chance to test these a few times at my usual spots, I figured I'd give an update. They work awesome as I stated earlier, I was able to make lines today that I was never able to make before. On steeper inclines the tires get just the right amount of "sidewall wrinkle". There is noticable wear on them but nothing I'm concerned about, and the rocks I run on are like sandpaper. A couple pics of my buddies freshly modded clod and roctapus crawling today. |
| Thread Tools | |
| Display Modes | |
