01-19-2014, 11:28 AM | #1 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
| Feeler - Lightweight Lower Cost Comp Beadlock
I'm looking at making some low cost lightweight beadlocks available for Comp crawlers. These would end up being about 24g (based on solidworks calculations) with stainless screws, aluminum standoffs, delrin rear ring, Lexan front ring, and 3D printed beadlock channels (ABS) (but weight without hubs). I'd be shooting for around $100-$125 shipped or so for a full set of 4 including hardware. (Available individually as well.) Like many of the available comp wheels: Variable width by doing different standoffs and spacers Variable offset by moving the wheel face in and out Compatible with vp and shift hubs Variety of wheel face designs available as well as materials Easily replace individual parts if something breaks But, what will set these apart is the low weight (under an ounce for each wheel), the beadlock system (don't have to worry about glue), the low price (I don't think anyone offers a wheel like this for around this price, correct me if I am wrong.) These should be compatible with most knuckle weights with the inside diameter of the rear ring at 46mm. Width ranges from about .7 to 1.5 (or larger if you want them to be super wide) There are color options as well, the bead channels can be in Black, White, Red, or Blue, but I can look into other colors as well. The Lexan can be painted to match or coordinate with any body color. The wheel faces would be Clear Lexan, Natural Aluminum, Black or White Delrin, and possibly G10 or CF (If I can get a good shop to cut them at a good price). These can also possibly be used for Scale Rigs with some scale wheel faces. There will be other wheel face options, but the initial design - snowflake pattern - is a nod to the old school snowflake wheel. The rear rings would be black Delrin for cost, but may be able to be upgraded to other materials. 1.9 option will be available as well, priced a little under the 2.2 I would think. So, what do you guys think? Is this something you would be interested in? Price point seem about right? Anything you would change? If there seems to be enough interest, then I will start a pre-order thread later. Pics of the initial prototype coming soon. |
01-19-2014, 01:00 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Feeler - Lightweight Lower Cost Comp Beadlock
I suppose, ideally, you'd want to get a couple of sets out to some testers to see how they hold up. I'm not entirely sold on the structural integrity of 3D printed material...yet.
01-19-2014, 01:41 PM | #3 | |
| Re: Feeler - Lightweight Lower Cost Comp Beadlock Quote:
But, yes, there will be testers... | |
01-19-2014, 02:38 PM | #4 |
| Re: Feeler - Lightweight Lower Cost Comp Beadlock So how would this work? Do you put the face inside the tire, and the ring (normally inside the tire) you would spin 180° and use on the outside of the bead? Or is there two rings, and you'd just move the face from outside the outer ring to inside the inner ring? |
01-19-2014, 04:29 PM | #5 |
| Re: Feeler - Lightweight Lower Cost Comp Beadlock For that case, you would need to get an additional set of rings so that the face was on the inside, and a ring on each outside.
01-19-2014, 09:16 PM | #6 |
Quick and dirty cell pic of the prototype. Holds the bead pretty well... |
01-19-2014, 09:17 PM | #7 |
Nice.
01-21-2014, 02:52 AM | #8 |
Rock Crawler Join Date: Jun 2009 Location: SF
Very interesting
01-21-2014, 07:50 AM | #9 |
The only kind of 3D printing that will hold up is SLS nylon...all others will fail over time. Why? They're non-composite materials that rapidly oxidize = not indicated for high impact products.
01-21-2014, 08:43 AM | #10 | |
SLS Nylon bead channels, at least this simple design, would end up being about $80 for a set of 4 wheels. That's a little higher than I think a lot of people would want to pay for just the bead channels, without really any added durability over the ABS. The bead channel is really the only place I trust the 3D printed material though. Once the part is made, it is just as stable as any other injection molded ABS piece. I can make the beads from FDM nylon, but I don't think it would be worth the extra material cost, set-up, and print time. These will be getting tested fairly soon, but I would be up to make a bead channel for an existing wheel design to have someone test (actually wouldn't be that hard, just a matter of modifying the bolt pattern...) | |
01-21-2014, 09:06 AM | #11 |
If you are already machining the face and rings why wouldn't you machine all of it? The production costs are much lower to machine a 2.5d part like that than to print it. Printing makes sense for parts that are hard to jig but that part that you are proposing to print is the easiest type to machine.
01-21-2014, 09:13 AM | #12 | |
01-21-2014, 09:16 AM | #13 | |
And btw, I think you should definitely make them. The more options the better. | |
01-21-2014, 09:37 AM | #14 | |
The first machining quote just came in... $456 for a set of 4 wheels IF i order 12 sets... I know they can be machined for less than that, but I still don't think they are going to come close to the 3D printed versions. | |
01-21-2014, 10:15 AM | #15 |
The real problem with printed abs is how quickly it oxidizes...this problem may be solved down the road. The part you're talking about isn't low stress due to the fact that the bead ring needs to exert considerable psi on it in order for the tire bead to sit properly. You'd be much better off machining this part...lexan?? Try to get a quote from a company that retails plastics as most of them have cnc services and if you order enough, it shouldn't be all that expensive per unit.
01-21-2014, 10:23 AM | #16 |
| Re: Feeler - Lightweight Lower Cost Comp Beadlock $456 for a set of 4 wheels IF i order 12 sets... This price reflects near earospace level machining... |
01-21-2014, 11:24 AM | #17 | ||
Maybe you have seen oxidation of the resin, but once printed, the thermal process sets the resin, and it retains the same properties as injection molded parts. ABS injection molded parts are some of the most common plastics that we all encounter. I'm pretty sure the tires or foams will degrade faster than the ABS... I couldn't find a single source talking about the oxidization of ABS after processing, so if you have a link, I'd love to see it. As far as low stress, it's the lowest stressed part of the whole assembly. You don't need THAT much force to hold the bead tight... really. Quote:
Different quote came to about $100 per set of 4 for just the bead channels, injection molded from delrin, would need to order 25 sets minimum though... I still think printed ABS is the way to keep these inexpensive, but still hold up to the abuse these rigs see. Machining cost would have to drop to below $30 for a set of 4 wheels (8 bead channels) and I don't think I'm ever going to get there unless I order 1000's of them. Unless you guys have a machine shop that can do a part like this for a reasonable price... | ||
01-21-2014, 11:32 AM | #18 | |
The wheel on the left is the same as the first pic on the first post, the wheel on the right has the wheel face on the inside of the bead channel and an extra bead ring on the outside. The offset can be changed easily with moving this configuration around and adding hub spacers if need be. Because it's not a glue on wheel, this can be changed at any time too. Foam tuning is easy, and no worries about needing a bunch of wheel sets trying different tires. | |
01-21-2014, 11:36 AM | #19 |
awesome.
01-21-2014, 12:14 PM | #20 | |
Feeler - Lightweight Lower Cost Comp Beadlock - Similar Threads | ||||
the ultimate lightweight alum. beadlock? (pic) | STANG KILLA SS | Tires and Wheels | 28 | 04-02-2011 02:45 PM |
