05-02-2014, 07:42 PM | #1 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
| plastidip and rubber
So i bought some wheels and tires off the classifieds and the PO had painted the rims and tires with black plastidip. I got it off the rims no problem but im having trouble removing it from the tires. i rolled it off the side walls with moderate difficulty but i cant get it out of the tread block and sidewall lugs. i thought about using a solvent but i dont want to damage the rubber and i cant pick it out with a toothpick or sewing needle as I dont want to damage the tire. any thoughts? |
05-02-2014, 08:03 PM | #2 |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
| Re: plastidip and rubber
Could we see a pic? I might say either find some sand paper or maybe a cone file. If its clogging the tread and it won't come out, a razor or dremel might be needed.
05-02-2014, 08:06 PM | #3 |
Newbie Join Date: Nov 2013 Location: SoCal
i don't know for sure if it will work with plasti-dip but washing the tires under really hot water and soap will usually clean them right up with a little bit of rubbing and scratching. also it makes them feel and look new, so that's a plus.
05-02-2014, 08:12 PM | #4 |
well its not clogging the tread, it just looks bad where the "Seam" is. ima try hot water tomorrow, but im not expecting much. il get a pic up tomorrow
05-07-2014, 11:13 AM | #5 |
Newbie Join Date: Apr 2014 Location: Beaverton
If you're still struggling to get the plasti-dip off, try coating the tires in WD-40 and let them sit for 5-10 minutes, then wash them off with hot water. WD40 turns plasti-dip into butter and comes right off with no residue.
plastidip and rubber - Similar Threads | ||||
servo plastidip question | cerpindicular | Newbie General | 1 | 12-28-2013 09:12 PM |
Plastidip Tube Work? | Propane | General Scale Talk | 20 | 11-29-2011 05:12 AM |
plastidip esc? | BrainDead | Axial Wraith | 9 | 08-20-2011 02:14 PM |
Motor Sensor plastiDip | arevir | Electronics | 3 | 04-05-2010 04:47 PM |
Plastidip scale spray in bedliner | RocknMud | General Scale Talk | 13 | 01-17-2007 06:06 PM |
