06-16-2014, 09:40 PM | #1 |
Rock Crawler Join Date: Jun 2012 Location: Nevada Desert
| 1.9 Growler Review First impressions: they are Pitbull tires. Soft and sticky, they stick to the bag and almost refuse to come out. Great tread pattern but the lugs seem very close together. Foams are dual stage open cell with a fairly firm inner and a medium outer. Size: they are similar to 1.9 TTC Baja Claws. The foams make them bulbous. Despite the flat tread surface without the foam, the tires swell mid tread. Sidewalls seem thick enough to grab well inside most (actual) beadlocks. These are mounted on Gear Head 1.9 12 Hole delrin wheels. During mounting I did have issues with beads slipping on the first wheel. This was more from establishing the purchase and dealing with the large foams. Crawler Innovations is definitely receiving a Deuces Wild Single Stage inquiry shortly. Weight used on the wheels consisted of 4.5 ounces in each front, 3 ounces in each rear; all flat lead weights. Some of the foam interference during installation was due in part to the space utilized by the weights. Also, the Gear Head wheels seem a bit thin compared to these tires. They look great as a combo, but be aware of the moderate mounting interference because of that difference. Of course I had to try them out. Nine o'clock in our neighborhood is fairly quiet so some mild running on concrete sidewalk, rough asphalt, flat loose rocks, and sandy hard pan was done at moderate speed. Not much can be said except that hard surfaces definitely result in traction roll. On the flat rocks these tires seemed to slide the rocks from underneath the rig. But the loose sandy surface on our hard pan driveway was impressive. The amount of grip mixed with moderate slip during turns really have me consider running Terra X 1.9 for next years AxialFest. Further testing on mixed textures of lava rock, loose to hard transitions, and much of the terrain we normally shoot in our vids will be happening very soon. Last edited by Nvghostrider; 06-16-2014 at 10:54 PM. |
06-16-2014, 09:42 PM | #2 |
| Re: 1.9 Growler Review
Can't wait to see your review. Got mine on the way. |
06-16-2014, 10:22 PM | #3 |
Review, pics, and vid. Let's see what I can get done tomorrow.
06-16-2014, 11:02 PM | #4 |
Rock Crawler Join Date: Aug 2012 Location: Koloa boy 808 2 DA 206
Are these In stock or did you get these special order ?
06-16-2014, 11:03 PM | #5 |
06-16-2014, 11:08 PM | #6 |
My team mate actually won them at AxialFest and they were too big for his rig. Traded him a set of Rockbeasts with CI foams.
06-16-2014, 11:58 PM | #7 |
| Re: 1.9 Growler Review |
06-17-2014, 02:53 AM | #8 |
Score! Yah been waitng for these to come out I need a big 1.9 for the new build I love the mad beast on my tundra these growlers looks sik!
06-17-2014, 08:54 AM | #9 |
My only qualm is the close tread pattern. Gonna test with stock tread and foams for at least a month before getting CI foams and possibly snipping a few lugs. Steven G. at CKRC was running Madbeasts with the smaller outer lugs trimmed and dubbed them "Mad Swampers". HUGE improvement on overall performance. These will be seeing trail duty as I rebuild the Scout from AxialFest. Normally this truck is more on rock bouncer and hill climb duty but I'll definitely hit as much varied terrain and traction as possible. |
06-17-2014, 05:53 PM | #10 |
06-18-2014, 01:39 PM | #11 |
RCC Addict Join Date: Nov 2011 Location: cold state
Received the new growlers! Thanks Doc! |
06-18-2014, 01:44 PM | #12 |
06-18-2014, 02:32 PM | #13 |
Just got mine. Mounted pics later. |
06-18-2014, 03:10 PM | #14 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Wow good review you have here, great job. I like those newer tires, they would be perfect on my jeep scx-10.lol.
06-18-2014, 03:31 PM | #15 |
06-18-2014, 06:09 PM | #16 |
Here's mine mounted. |
06-20-2014, 09:14 AM | #17 |
Short run last night (vid coming soon) with pretty positive results. On a mix of rough and smooth lava rock, some dry and loose transitions to hard surface, and a few short steep inclines I am impressed so far with these tires. This rig has had many tires and compounds under it and so far this has become a new favorite. I can foresee issues in loose/sandy conditions but we will face those issues when they happen.
06-20-2014, 11:59 PM | #18 |
06-21-2014, 12:19 AM | #19 |
They look like they are doing pretty well. I'm guessing they will get better the more you use them. You think the foams are better than past pitbull foams? Just form feeling them they seem better to me.
06-21-2014, 01:25 AM | #20 |
I always thought the old outers were too soft. With the slim width of the Gearheads these new foams are just on the edge of overstuffed but nothing like the terrible fit on Swampers with stock foams. If the tires or wheels were vented I think a heavier rig would easily fold these new foams over.
1.9 Growler Review - Similar Threads | ||||
Official Review - Pit Bull Growler - 1.55 | dezmoon | Tires and Wheels | 396 | 07-25-2015 02:53 PM |
Review,, 1.9 Pit Bull Growler, Prototype | dezmoon | Tires and Wheels | 206 | 10-16-2014 11:31 PM |
2.2 growler poll | THEPITBULL | Vendors Tires and wheels | 36 | 07-11-2014 10:20 PM |
