| | #1 |
| Rock Stacker Join Date: Apr 2004 Location: FRONT DIGGING YOUR MOMS YARD
| Has anyone tried to mount Jumbo Swamp dawgs on Maximizer beadlocks? Does any one have photos of swamp dawgs used on their crawling rigs. Please feel free to give all kinds of input/photos/ideas. Thanks. By the way i did a search for this application and found zip nada no mas ZERO nuttin. Thats why im asking, I see how sometimes people ask before looking for them self. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
| I don't see why it wouldn't work..... they are both 3.2 rims and it should pull the bead in closer together to make a nice buldgy tire. |
| | #3 |
| I wanna be Dave Join Date: Jan 2004
| Talk to Grizzly. I think he's done this. |
| | #4 |
| Pebble Pounder Join Date: Mar 2004 Location: Massachusetts
| | #5 | |
| | #6 |
| | #7 |
| Quarry Creeper Join Date: Sep 2004 Location: On my acre and a half of Gods Country. Prosper, TX
| I just put some swamp dawgs on maximizers, and I didn't have any problems. I am using them on my E-Maxx crawler that is just locked up. I think I am going to put these on a Pede, if or when I get one. I think you need a larger tire for the Maxx. |
| | #8 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| I put my JumboMaxx Swamp Dawg's on Maximizer beadlocks. The problem is that the width of the JSD's tire bead is twice what it is on a standard Maxx tire. Kona Joe fixed this by cutting the rings, I fixed it by cutting the bead "lip" in half with a razor blade. Either way is good. EDIT: Here's what I did. 1) Pull the bead out and mark the center with a marker 2) Then cut the bead along the mark line. Now your JSD's will fit the Maximizers and the rims will still werk with other tires. Last edited by Grizzly4x4; 01-27-2005 at 10:03 PM. |
| | #9 |
| Newbie Join Date: Sep 2004 Location: denville , new jersey
| i put jumbo swamp dawgs on maximizers on maximizers it was easy as cutting on the molded lines on rings and they are awsome best thing i did with my dawgs. |
| | #10 |
| Quarry Creeper Join Date: Jul 2004 Location: Elizabeth City
| Cut-n-shut jumbos. Waiting for the glue to dry, then they are goin on the maximizers. I did the 3/16 off of the rings. I had an extra set, so I can still use other tires. More pics after bead rings are done. |
| | #11 |
| Newbie Join Date: Feb 2004 Location: Northern Utah
| Griz's method will allow you to continue to use the bead locks on other tires, where as trimming the ring will make mounting standard width beads questionable. I trimmed the tire bead on my Dawgs. 'Pony |
| Thread Tools | |
| Display Modes | |
