08-28-2014, 12:30 PM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Swartz Creek ~ MI
| Home Made ~ Metal 1.9 Bead Lock Rings !!! Home Made ~ Metal 1.9 Bead Lock Rings !!! Cool discovery: Do you want Metal 1.9 Bead Lock Rings for your Scaler or Crawler ? Get [8] of them for $10.oo / / Compared to Axial (2) for $12.oo Ok Then Buy ~ (4) Packages of: HILLMAN ~ Machine Bushing / Washers / Zinc 1-3/8 x 2-1/8 x 14GA ~ Size Part Number: H# 883572 They come in packages of (2) For $2.25 to $2.75 At Big Box ~ Hardware Stores Or your local hometown Hardware Store may have them or could Order them for you. {Just line up your current bead lock rings to the washer & mark the holes then drill them out} {Best to use Duck Tape to hold your bead lock rings to the washer for drilling the holes} {Use a drill bit just slightly larger than the 2mm size screws or 3mm size that you're using} [They are thinner then your stock rings, So if you're using 2mm x 12 screws use washers] ( You can Sand & Paint them to match your Scaler or Crawler or just leave them Silver ) Last edited by Stomper Fan 777; 08-28-2014 at 03:45 PM. |
08-28-2014, 06:13 PM | #2 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Re: Home Made ~ Metal 1.9 Bead Lock Rings !!!
Had a flashback to 2006. Thanks |
08-28-2014, 06:53 PM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Lol....... That's funny
08-29-2014, 08:56 AM | #4 |
| Re: Home Made ~ Metal 1.9 Bead Lock Rings !!! { Was That Sarcasm ? } ~ LOL I knew the idea about using washers for bead lock rims have been around since the dinosaurs. It was just the fact that I found the exact same washer size as 1.9 bead lock rings. That was the point I was trying to make and just wanted to pass it along. And for the ones that may have not knew about this idea... |
08-29-2014, 01:07 PM | #5 |
No sarcasm here brother. Dudes quote just made me laugh. I never knock fab. But those gear head rings are pretty nice IMO. Especially with scale hardware.
08-30-2014, 03:11 PM | #6 |
| Re: Home Made ~ Metal 1.9 Bead Lock Rings !!! * Gear Head 1.9 Sixer Beadlock Wheels * Home made ~ Metal Bead Lock Ring's * Pro Line Interco TSL SX Super Swamper XL 1.9 Tire's Last edited by Stomper Fan 777; 08-30-2014 at 03:16 PM. |
08-30-2014, 03:36 PM | #7 |
Truck looks good. If I wanted wheel weight I would definitely consider these. |
09-02-2014, 03:05 PM | #8 |
Newbie Join Date: Jul 2014 Location: Central Kalifornia
Good idea with the washers, had not thought about that!
09-11-2014, 07:51 PM | #9 |
| Up-Date 9/11/2014 Up-Date 9/11/2014 I Painted the Metal Beadlock Rings ~ Flat Black & Inside the bolt holes with Gloss Black. Just a better look then the Silver I think. ~ Also added (24) 2mm washers to all the bolts. It's kind of neat to see my truck up on Blocks ok well Tupperware bowls ~ LOL Someday I will get a set of them Scale 6 ton Jack Stands... |
Home Made ~ Metal 1.9 Bead Lock Rings !!! - Similar Threads | ||||
Bead lock rings ? | Subytuner | Vaterra Twin Hammers | 5 | 04-09-2013 03:50 PM |
G made bead lock rings by Gear Head RC | RPP Hobby | RPP Hobby | 0 | 02-26-2013 08:43 PM |
vanquish bead lock rings? | demonoid369 | Tires and Wheels | 9 | 07-06-2012 11:43 AM |
2.2 Bead lock Rings | wayfastwhitey440 | Newbie General | 1 | 06-24-2006 02:20 PM |
