10-25-2014, 11:38 AM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: Vancouver Island, BC, Canada
| Narrowing problems (w/ glue?)
just narrowed my first set of tires and am having problems with the glue. I washed my tires inside and out with a scrub brush and hot soapy water followed by a good rinse. I am using IC-2000 Tire Glue Rubber Toughened (the black stuff). Glue is taking upwards of 3 minutes to set enough for me to release the pressure. Even after this long it easily separates. After doing the whole tire, I had to do both a bead of glue all the way around the cut on the inside and the outside to get it to be strong enough to not easily separate. Now the glue is making my tire turn white and hard anywhere near the glue. Am I just using the wrong glue? Stuff said that "this is the best glue for tires and cut and shut". looks like **** and isnt holding up, plus changing the softness of the tire. What gives. |
10-25-2014, 12:22 PM | #2 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: Narrowing problems (w/ glue?)
I use Losi thin tire glue.
10-26-2014, 01:55 PM | #3 |
Pebble Pounder Join Date: Oct 2004 Location: Central NJ
There should be an immediate bond. If too much is applied it takes much longer. A little dab'll do ya.
10-26-2014, 03:21 PM | #4 | |
| Re: Narrowing problems (w/ glue?) Quote:
ie: https://www.hobbyking.com/hobbyking/...Glue_1_oz.html I know standard CA glue works fine for adhering the tire's bead to the wheel if bead locks are not utilized. But wheel flex is minimal when compared to the tire's necessary surface conformity (flex). but then I don't really know much as I've never cut/resized my tires. Last edited by TacoCrawler; 10-26-2014 at 03:35 PM. | |
10-26-2014, 06:00 PM | #5 | |
Pretty sure these tires are hooped, but at least I only precut 2. | |
10-26-2014, 06:39 PM | #6 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
All you have to do is use some CA quick setup glue first to get the tire together, then turn the tire inside out and run a bead of your ic2000. I've done dozens of sets of tires this way, it works great! |
10-26-2014, 07:07 PM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
The video in this link helped me. Use thin CA first followed inside by IC-2000. How-To: narrow a tire - Scale 4x4 R/C Forums |
Narrowing problems (w/ glue?) - Similar Threads | ||||
What do you guys use to glue tires other than CA glue? | country_crawler | Tires and Wheels | 38 | 03-17-2015 11:10 PM |
To glue or not to glue...rear tires | Snipervision | Losi Mini-Rock Crawler | 3 | 12-24-2010 11:01 AM |
best glue for narrowing wheels? | F-150Highlift | Tires and Wheels | 8 | 02-03-2010 08:29 AM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
Memory Foams To Glue or not to Glue? | Rig Rocker | Tires and Wheels | 1 | 09-30-2009 10:45 PM |
