10-31-2014, 04:53 AM | #1 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
| Add weight to VP method 1.9 wheels
I am looking for ideas to add weight to my VP method 1.9 wheels. I was considering just wrapping some stick on weights inside under the foams but didn't know if that would make the foams more stiff? How have you guys added weight to these wheels?
10-31-2014, 08:56 AM | #2 |
Pebble Pounder Join Date: May 2013 Location: Lees Summit
| Re: Add weight to VP method 1.9 wheels
I'd recommend not actually adding weight to the wheels themselves. It increases rotational mass and is much harder on parts. I've started using the Blue Monkey knuckle weights and absolutely LOVE them. They have versions to fit just about any knuckle you could be using. I have the VP 8-degree knuckles on mine currently. |
11-03-2014, 10:52 PM | #3 |
I joined the Band! Join Date: Sep 2014 Location: USA
why do you wanna to add weight to your VP method 1.9 wheels?
11-04-2014, 04:24 AM | #4 |
To lower the cog and help keep the wheels planted on the ground. My truck is very light, it's just over 5lbs with the battery.
Add weight to VP method 1.9 wheels - Similar Threads | ||||
1.9 VP method weight | novarider | Tools, and Procedures | 3 | 10-29-2014 03:27 AM |
How much weight should I add to beadlock wheels on the axial ridgecrest? | axial 4x4 crawler | General Crawlers | 5 | 07-25-2013 07:55 AM |
To Add Weight or Not To Add Weight??? | JCSXJ | Axial Wraith | 7 | 02-16-2012 11:45 AM |
Add weight wheels with less loss of power... | nut_up_racing | Tires and Wheels | 19 | 11-26-2011 04:50 PM |
Using lead tape to add weight to wheels. | Khador12 | Losi Mini-Rock Crawler | 6 | 12-26-2008 10:41 PM |
