12-08-2014, 06:28 AM | #1 |
Rock Stacker Join Date: Oct 2006 Location: ezel
| best tire for hard packed dirt
Hey guys what is the best 1.9 tire to use on hard packed dirt? I do prefer a lower OD tire for scale look but can go taller if I have to. Thanks in advance |
12-08-2014, 09:42 AM | #2 |
Rock Stacker Join Date: Mar 2011 Location: Madison, Alabama
| Re: best tire for hard packed dirt
Alot of Hard packed dirt hill climbs where I run close to my house and the best tires I have found is 1.9 TSL SX, (Small ones and XLs) R35 Ripsaws and Mud slingers (I have 1.55s and had a set of the small 1.9s old style harder compound) but the TSLs and Ripsaws with CI Foams Sidehill better. All of these had CI foams in them BTW. The Boggers/Mudslingers do best in a straight up climb but if the truck ever turns sideway then it will actually slide down the hill due to the Lateral Lugs. Also the Boggers/Mudslingers will wear ALOT faster than the TSLs and Ripsaws from my Experience. Ive also ran RockBeast and they do OK but not near as good as the others mentioned from my experience.
12-08-2014, 10:14 AM | #3 |
Thanks blackfox93 I will be using on a new diesel pulling class so its just straight going no side but most time the track is very hard packed. |
12-08-2014, 10:20 AM | #4 |
Don't most RC pullers use modified Tamiya TLT tires?
12-08-2014, 10:20 AM | #5 |
| Re: best tire for hard packed dirt I would go with a Bogger/Mudslinger then but in a pulling senario I would expect some accelerated wear due to wheelspin but I think they will do you right |
12-08-2014, 10:34 AM | #6 |
RC4WD actually has a 1.9 pulling tire but Im not sure what the rules allow for your class. Id like to build a puller but nobody around here does it and rules vary everywhere you go even for local crawling events.
12-08-2014, 10:42 AM | #7 |
tlt or pumpkin on the 4x4 class where allowed...the rules on the diesel class are 1.9 dot tire nothing v tread don't remember the width allowed right now I think its 1.65 but we are allowed duals on rear.
12-08-2014, 10:48 AM | #8 |
If you do decide to build best to go by the NR/CTPA rules.some clubs out West go by a lil diff.rule
best tire for hard packed dirt - Similar Threads | ||||
Dirt/Mud Trail tire? Suggestions? | Oldskoolcj | Tires and Wheels | 23 | 03-25-2013 05:51 PM |
What 1.9 tire for loose gravel/dirt/rocks? | josruu | Tires and Wheels | 11 | 04-26-2011 01:39 PM |
best 2.2 tire for dirt/mud? | swamp_rat | Tires and Wheels | 10 | 06-27-2006 12:31 PM |
New HPI Dirt Claw Tire | sicj | Tires and Wheels | 17 | 02-19-2006 10:57 AM |
