Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: maximizer with gaint trac tires
Old 01-31-2005, 12:01 PM   #1
Default maximizer with gaint trac tires
does anyone have pic with the giant trac tire on a maximizer rim.i tryed this yesterday and i could not make them work.
thanks again.
1beatjeep is offline   Reply With Quote
Old 01-31-2005, 04:56 PM   #2
I thought that the giant trac was a clod tire, with a 65mm inner Diameter
and the Maximizer is a t-max wheel with a 74mm inner Diameter. So that is why it will not fit.
reedpowell33 is offline   Reply With Quote
Old 01-31-2005, 05:56 PM   #3
Est. 2003
PinchFlat's Avatar
YES.... It can be done. I was told it was a pain in the A$$ the stretch them to fit, btt here is proof. (BTW... this is the second time I have seem this)
-PF
PinchFlat is offline   Reply With Quote
Old 01-31-2005, 06:02 PM   #4
willyrocket's Avatar
Lots of soap and water and a pry bar!?!?!?!
willyrocket is offline   Reply With Quote
Old 01-31-2005, 07:04 PM   #5
they stretch over way easy! The rubber is so gummy.
Also, if you just cut the flat part of the beads off the will go right over.
SR5Dave is offline   Reply With Quote
