Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Scale bolt tool
Old 12-16-2014, 03:17 PM   #1
Default Scale bolt tool
I got a set of used rc4wd 2.2 wheels with 16 tiny scale bolts holding the wheel together. They did not include the little tool for them. Looking around, I have found some 2.5 mm nut drivers, but with tax and shipping they are about 20$. Anyone know where I can get one of those tiny bits that goes in the end of a hex key? Even just to use for an hour?
Thanks!!
Turtlejon is offline   Reply With Quote
Old 12-16-2014, 03:32 PM   #2
~THE SCALE SHOP~
Default Re: Scale bolt tool
its easier than that. just make yourself a "tommy tool"
you can use a metric screw and slide it over the scale hex head and tighten them.
my pics are down, but here is pics of the origonal tommy tool.
its a traxxas driveshaft pin with a handle brased on. you can also use a screw.
if you have 2.5 scale head, then you need to use a M3 socket head cap screw. it has a 2.5mm hex in it.
if you have M2 scale bolts. then need a M2.5 socket head cap screw
STANG KILLA SS is offline   Reply With Quote
Old 12-16-2014, 06:09 PM   #3
LockedUp?
$6 + post
2mm Hex Socket Driver (tip)
altd896 is offline   Reply With Quote
Old 12-16-2014, 06:34 PM   #4
The 2mm one is too small, these are 2.5.
That tool gave me an idea! I used a 2.5 mm cap head screw, and put 2 locknuts on it, tightened them together against each other, then put a regular cross wrench over the nuts.
Working so far!
Thanks y'all!!!!
Old 12-17-2014, 09:19 AM   #5
~THE SCALE SHOP~
sweet.
Old 12-22-2014, 12:52 AM   #6
I joined the Band!
I also think 2mm is too small.I used the 2.5mm too
Fuamuler is offline   Reply With Quote
Scale bolt tool - Similar Threads
Scale Tool Boxes skengines Paint and Body 2 05-01-2014 02:29 PM
rc4wd scale hex bolt tool HELP discgolferlee Tools, and Procedures 20 06-15-2013 07:26 PM
Scale tool box Mechanicalbob Scale Accessories 3 06-02-2009 05:13 AM
