| | #1 |
| Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Here is what I'm thinking, if you cut the mulchers with the sidewall so they would be a long strip of rubber, and glued in a peice of another mulcher tire to one end of the strip, and the other end of the insert to the other end of the strip, increasing the OD and ID of the tire at the same time. My goal would be either a 4" (Pro-line 40 series) or a 4.5" (Hot Bodies jumbo's) inner diameter so I could use one of those rims. So then, the tires would be either 6.75 or 7.25" tall. What do you think? There would be a little deformation, but not to where it would be noticible or affect performance. Would IC2000 hold up well? |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Dec 2004 Location: in limbo
| this is going to cost you almost more than its worth...why not find a set of very worn 7" tires and glue the mulcher strip to the outside after you take all the old tread off |
| Thread Tools | |
| Display Modes | |
