02-03-2015, 12:35 AM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: BC, Canada
| Axial 6 bolt hubs
Was messing around on rpp and found some axial hub adapters..... I'm wondering if the pattern matches vp wheels or rc4wd? anyone know? link...... Axial Wheel Hub Adapters (2pcs Narrow, 2pcs Wide) |
02-03-2015, 05:08 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: martins ferry
| Re: Axial 6 bolt hubs
Listed right in the description Features Includes two narrow hubs and two wide hubs per package Compatible with our licensed Trail Ready wheels Compatible with most Vanquish wheels Eliminates the need for a 12mm drive hex Sent from my iPad using my finger |
02-04-2015, 02:53 PM | #3 |
That will learn me........... thanks.
02-04-2015, 04:59 PM | #4 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
Please don't use them though, they are pin drive you will destroy them easily. Why not just go for the proper SLW hubs? Then you run an aluminum hex,and won't lose the pin if you take the wheel off.
