Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Who's guan help the Brit!
Old 07-01-2015, 01:15 PM   #1
Default Who's guan help the Brit!
Hi guys Iv searched the forum,I can find pics but I'm after some step by step guidance on reducing some 2.2 boggers to 1.9...also the best glue to use!! Any help would be super!
Paul 88 is offline   Reply With Quote
Old 07-01-2015, 01:30 PM   #2
Scale Detail Engineering
Default Re: Who's guan help the Brit!
You want flexible CA glue for cut-n-shuts, something like this:
Bob Smith Industries IC-2000 Black Rubber Toughened CA (1oz) [BSI118] | Maintenance - AMain.com - AMain.com
johnnyh66 is offline   Reply With Quote
Old 07-01-2015, 02:16 PM   #3
MODERATOR™
EeePee's Avatar
Reducing 2.2 Moabs to 1.9
EeePee is offline   Reply With Quote
Old 07-02-2015, 07:06 AM   #4
binaryterror's Avatar
I couldn't disagree more with the old school of tire glue thoughts. IC2000 is crap.
I've made about 30 sets of 4 tires in all sizes for Comp use, never had one let go at the glued seam since stopping using IC2000. The best glue hands down is the AKA tire glue.
binaryterror is offline   Reply With Quote
Old 07-02-2015, 08:01 AM   #5
MODERATOR™
EeePee's Avatar
I liked sniffing the Losi glue and occasionally used it to do tires.
Old 07-02-2015, 10:32 AM   #6
I'm using Loctite 406 for modifying tires
Never liked IC2000.......
Henkel Loctite - CA 2012 - Loctite Instant Adhesives for Plastic & Rubber
JENS is offline   Reply With Quote
Old 07-02-2015, 12:22 PM   #7
5th D Owner/Driver
cboggs's Avatar
I also use the Losi tire glue- thin.
Losi: Losi Tire Glue, Thin: Losi (LOSA7881)
cboggs is offline   Reply With Quote
Old 07-02-2015, 01:08 PM   #8
I've only used IC-2000 once when I did my Cut-N-Shut's years ago... at the time, it's what was recommended.
Sorry for giving you outdated info Paul.
Old 07-02-2015, 04:38 PM   #9
Y-Town Crawlers
Del Monte's Avatar
X2! 406 is great stuff.
AKA tire glue works well too, and is cheaper.
Del Monte is offline   Reply With Quote
Old 07-03-2015, 01:09 AM   #10
Cool! Iv got some loctite 406 and some flexible black rubber 'CYANOACRYLATE' glue I thought to do the inside of the tyres/fill any gaps I'm new to working with rubber.... steel is my passion
Old 07-10-2015, 05:23 AM   #11
got one done
Old 07-11-2015, 03:49 PM   #12
thats all four done and fitted
