| | #1 |
| Newbie Join Date: Feb 2005 Location: buried in snow in upstate ny
| i dont know if anyone has done it this way, but this is how i narrowed the clod wheels. top wheel is stock middle wheel is where i cut in half (i cut it just behing the wheel center) bottom wheel shows the section i took out--doesnt look like a big chunk--but wait.......... once you clean up the 2 halves, you can test fit them together by slipping the inner half over the outer half (should be a light resistance going together). by doing it this way, if you made the cuts a little off, it provides a very stong overlap joint. once your satisfied with the fit, glue the 2 halves together, i use ambroid pro weld plastic liquid cement. it'll actually melt and fuse the plastic forming a strong bond. if you have chrome wheels (or painted), make sure you sand the chrome (or paint) off the areas to be glued for a proper bond. now you can see how much i actually narrowed compared to a stock wheel. Last edited by turbodart; 02-06-2005 at 06:57 PM. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| | #3 |
| Rock Stacker Join Date: Nov 2004 Location: Gorgeous Santa Barbara
| hey, got a pic of the drive side? i am wondering how much backspacing you have now. Thanks Shane |
| | #4 |
| therims are about 2 1/4" wide overall end to end. as far as bacspace on the wheels, its about 1/8" . its almost no backspace at all. i guess i haveto be a little smarter on the terms to use in the search. i couldnt find a whole lot on narrowing wheels, but i knowits out there---cant teach a old dog new tricks i guess. |
| Thread Tools | |
| Display Modes | |
