07-30-2015, 12:58 AM | #1 |
| Axial "Trail Ready" bead lock inquiry bought a used set on a whim the seller failed to send the hubs with the wheels. claims they were forgotten... and I'm still waiting Didn't realize the center adapter were direct pin mount design. Not sure I'll be liking that. I'd have preferred wheels using the 12mm hex But I paid for them... so might as well use them. Question is... Will I need extra pins because I'll be losing mine just about every time I change a wheel ??? grr Has anyone found an alloy adapter that can replace the plastic centers ? I saw some on rc4wd for their 6 lug steel wagon wheels... but it doesn't reference the lug pattern equations any body here know something ? thx if ya do |
07-30-2015, 01:01 AM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Axial "Trail Ready" bead lock inquiry
Those should have a Vanquish SLW bolt pattern.
07-30-2015, 01:20 AM | #3 |
...thanks. tho' VP tends to be spendy ------------ Anyone know if the Axial 2.2 Method's lug patten is the same ? I see those have the 12mm hex mount. if they might work... I'd still need find the part # to order ?? anyone tried ? maybe these ? 1.9"/2.2" 6 Lug Steel Wheel Hex Hub +6 Offset ----------------- edit: I just picked up a set of the Axial IFD Method 2.2 plastic hex hubs... on ebay for $ 11. shp'd :crosses fingers: Last edited by TacoCrawler; 07-30-2015 at 02:17 AM. |
07-30-2015, 02:42 AM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
The Trail Ready wheels are part of the Axial IFD series just like the Method, the 12mm hex hubs (#AX31266) and 12mm hex hub conversion (#AX31074) are for the IFD series wheels. They should fit without a problem. No idea if Vanquish hubs or RC4WD hubs will fit.
07-30-2015, 08:25 AM | #5 |
If it's the same as the Axial Method wheels, the VP SLW hubs will fit.
07-30-2015, 08:59 AM | #6 |
| Re: Axial "Trail Ready" bead lock inquiry |
07-30-2015, 02:34 PM | #7 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Harley did video on them and the vanquish fit according to the video. Also if what you bought dosnt fit let me know. I've got some extra.
07-30-2015, 03:20 PM | #8 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Its a whole 30 bucks for VP hubs plus a couple of extra bucks for that 4-40 hardware (yes , they actually use SAE. The crappy plastic hubs that came on those wheels on the yeti were M3).
07-30-2015, 03:36 PM | #9 |
I've used the plastic ones for over a year on my scx10 with Holmes hobbies electronics an not broken one. I also pull a trailer with my sons dingo on it. We' trail run at the golf course daily. The extra set I have is plastic. I agree with you about the vp cost. There stuff is good but with me my son and wife running rc's we don't buy much vp
07-30-2015, 03:57 PM | #10 | |
where's this Harley video ? I looked... but he has too many posts and I'm not sure which thread it may be in !? folk... realize these are budget wheels... and I have little interest in spending a small fortune on them. I really wish to go with a tire nearer 6" tall... But rc4wd's interco tsl is the tallest 2.2 @ 5.75", that I know. That in mind... wasn't really wanting to go 3.8" wheels as those tires are too tall and require using adapters to make those fit a 12mm hex or use a 14 -17mm hex and appropriate wheel. Costly investment I'll think to guess. Not even sure a Wraith drive train can be geared low enough for larger tire use !? :dunno: btw... I'm building a 1/6 scale jeep bodied crawler... and that is the reason for wanting the taller tires. These idf 2.2 wheels will work for now. 'cause they were cheap to obtain. sorta. But I'm not sure if rc4wd interco 5.75" tires will fill the wheel wells as much as I would like. Anyone know if the rc4wd interco's might fit the idf wheels decently ? here's my 1/6 scale mocked up with the stock Wraith 2.2 ripsaw tires/wheels. But I'm going to use 5 1/4" BFG Krawler tires mounted on the idf's. ^ at least for the mock up/build. (the wheel offset will be slightly wider then in these pics) I'm attempting a scale look... but larger then a Wraith but not going for a monster truck look either. ------------------ Quote:
07-30-2015, 08:49 PM | #11 |
I watched on his u tube site. One one of the wraith build ups.
07-30-2015, 11:42 PM | #12 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
I had the pin and hex axial plastic hubs on my wraith. I stripped both versions within 3, 2s lipos. If you have a heavy weight rig with any power whatsoever, you will need to go to proper slw's. As a side note, I had very poor luck with the ifd bl, it threw a bead on losi comp claws, rc4wd boggers and pl tsl xl's. I got axial rockstars with the tsl xl's and have had 0 issues. Sent from my Nexus 5 using Tapatalk |
07-31-2015, 06:05 AM | #13 | |
| Re: Axial "Trail Ready" bead lock inquiry Quote:
https://www.jconcepts.net/shop/scorp...in-racer-tires | |
07-31-2015, 12:43 PM | #14 | ||
I generally gear low and crawl slow so hopefully I'll get away with it... for awhile anyways. Yeah I've read that some tires don't keep a bead. But in one of those reads... someone said the Proline tsl xl's held. hmmm maybe I'll try using a little E6000 and see if that helps !? Quote:
nice to know there are options out there. Last edited by TacoCrawler; 07-31-2015 at 12:48 PM. | ||
08-01-2015, 02:10 PM | #15 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
I bought a couple sets of the trail ready 2.2'' and I bought the Vanquish .475 SLW hubs and I'm using Axial hubs that come in the Wraith kit and I went McMasters and order the black 4/40 for the hubs and have not had any problems with them Last edited by kgb424; 02-04-2016 at 03:45 PM. |
08-01-2015, 04:26 PM | #16 | |
4/40 still blows on an all metric rig... ALIMO My LHS sells 4/40 so no big deal... but then I'd need another ball driver thanks for the verification that they work | |
08-01-2015, 05:16 PM | #17 |
what do mean by offset I'm using .475 SLW hubs cause when I bought the rims they came with the plastic hubs or hexes or what ever you call them they give you a short hub and a long hub they are for my Wraith and the short hubs were to short the rims rubbed on the knuckles and the long hubs were to long the wheels stuck out and just didn't look right to me the Vanquish SLW .475 hubs are in between are the perfect hub length for my setup and I like the width Vanquish make several different length hub or hexes and they are 4/40 you need 24 four rims a set McMasters sells them in boxes of 50 or 100 Last edited by kgb424; 08-01-2015 at 05:25 PM. |
08-01-2015, 07:38 PM | #18 |
oh my bad... I miss read your prior posting's description. not sure how... was plain as day. :doh: The wheel's backspacing remains what ever it is... ? :dunno: offset is basically determined by the length of the hubs and how far out board the wheels fit beyond the axles hex's. Vanquish offers several different slw hub offsets. sooo.... .475 is closest to what the factory plastic hubs offer ? sorry I don't have the original plastic hubs for comparison... yet I ordered some new... but not the original pin mount... instead the hex conversion type. meh... if they break... I give the VP slw hubs a try. |
08-01-2015, 09:23 PM | #19 |
the ones that came with my rims where the pin type and the .475 were in between the short and long plastic hubs that came with the rims I used .475 for the fronts and backs rims I have seen some guys using a .475 hub in the front and a .600 hub in the rear on there Wraiths |
08-02-2015, 11:43 AM | #20 | |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Hope this helps | |
Axial "Trail Ready" bead lock inquiry - Similar Threads | ||||
HELP, tired of "searching"...."bead-lock" question? | BigMark | Newbie General | 2 | 10-14-2007 10:22 AM |
