02-11-2016, 12:03 PM | #21 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: Looking for foam help
Um, you could buy them off of crawler-innovations when he re-opens his website. But you want the tools, so your probably going to need a foam knife with a blade that looks like the grooves on the comp cut foam, I believe the foam knives have to be plugged in to heat up the blade. You'll also need to build a foam cutting device, something to clamp your hot foam knives to, and something that keeps your foam rotating in one spot (an old rim, some bearing, and a shaft to rest them on) all bolted/screwed to a base of your choosing. Honesty it sounds like a lot of work just to modify a pair of foams. |
10-15-2018, 01:54 PM | #22 |
Newbie Join Date: Dec 2016 Location: Dallas
I'm having this same issue with my rear CI foams. I have dual stage proline foams in the front with zero issues. Seems like I always have that issue with the CI foams.
10-15-2018, 05:21 PM | #23 |
I have never felt the need to vent any of my tires and they conform just fine to rocks. |
Looking for foam help - Similar Threads | ||||
Deuce's Wild XL Foam Pair; 3.8" ID; Yeti XL Foam / BFG Krawler Tire | Nova's Ark | Crawler Innovations | 12 | 08-31-2015 08:20 AM |
Axials with standard foam Vs Losi with Memory foam - bounce test | Mud Puppy | Tires and Wheels | 3 | 10-24-2010 11:10 AM |
Nova foam vs. Proline 2 stage oversize foam | sbarnesvta | Tires and Wheels | 36 | 05-07-2010 09:04 AM |
do i trim the memory foam like i did the reg foam with the stock tires? | bmuenter | Tires and Wheels | 8 | 08-15-2008 08:59 PM |
