01-02-2016, 08:50 AM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
| Looking for foam help
Hey guys, I recently installed a set of PB Growlers with 5.25 DD foams with medium outers on Proline Faultline bead locks. After a short time running this happened: The inner foams seem to stay put, but the outer walks all over the place. Is this something that CI tuning discs will solve? This is the first time I've run into this and have no idea how to solve it! Thanks for any input. Sent from my Jitterbug |
01-02-2016, 02:43 PM | #2 |
Pebble Pounder Join Date: Apr 2013 Location: Charlotte, Mi
| Re: Looking for foam help
Some people recommend gluing the inner to the outer but I would wait on a more experienced person to chime in before permanent modification.
01-02-2016, 03:57 PM | #3 |
Quarry Creeper Join Date: Jan 2014 Location: Western Wa. Mose Capital of the World
If you are not already using C.I. Comp cut inner try them. The groves in the inner foam help stop the outer foams from migrating from side to side. Attachment 333833 You can cut groves the the non-comp cut foams your self. Last edited by Tom G; 08-29-2016 at 04:49 PM. |
01-03-2016, 05:43 AM | #4 |
Thanks for the input guys! As a side note, these Growlers work fantastic on the rocks, I'm quite impressed and cant wait to to get this minor issue resolved! I just sent CI an email with this same question, maybe I'm using the wrong foams. |
01-03-2016, 05:10 PM | #5 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
Are you venting the tires or not? I've seen that issue more with a non-vented tire.
01-03-2016, 06:46 PM | #6 |
The wheels are vented, it might not be ideal but I bore a hole (cautiously) through the existing holes in the wheel all the way to the outer foam. I just can't bring myself to cut the rubber! Sent from my Jitterbug |
01-04-2016, 06:16 PM | #7 |
LOL, buy yourself a leather punch tool and use the smallest setting. I usually put three holes in my tires, all in the center of the tire in between the tread and try to spread the holes out evenly around the tire. I've never had an issue with tearing tire because I vented them.
01-05-2016, 11:14 AM | #8 |
Quarry Creeper Join Date: Dec 2015 Location: San Diego
I run a 1/8 scale Tekno EB48.3 on 4S as one of my race RC buggy's. I've vented the tires with a leather ho,e punch, I've never had a tire rip apart from venting. I did have 4 tires shred themselves once, but that's because I put a 6S battery from one one of my helicopters in the EB. Wanted to exactly how fast I could get it to go. Hit the throttle, the car squatted jumped off the line and within maybe 6-8 feet pieces of tires were going everywhere. |
01-05-2016, 12:28 PM | #9 |
I guess my concern with venting the tire is due to the fact that some of the trials we run have some shallow standing water, I feel that with a vented tire you WILL introduce water to the foam, whereas with a vented wheel you have the height of the tire/wheel before introducing any. I know it might be splitting hairs but that's my OCD kicking in!! |
01-05-2016, 05:00 PM | #10 |
You could always go with a CI Deuces Wild setup with vented tires, they're closed cell and water wouldn't be an issue. I used this setup on multiple 2.2 rigs and was quite happy.
01-05-2016, 06:38 PM | #11 |
That's a pretty good idea, I might give them a try as I've never run a set of them before. Sent from my Jitterbug |
01-06-2016, 09:56 AM | #12 | |
Pebble Pounder Join Date: Oct 2015 Location: kingsport
| Re: Looking for foam help Quote:
I'm with you ... I use ci dual stage and afraid of getting water in them plus I run omf's on proline tsl and they are a bastard to get apart and air out ... Plus I'm ocd about cleaning my tires after every run so the foams would get soaked ... Sent from my iPhone using Tapatalk | |
01-08-2016, 02:52 PM | #13 |
Well....I tried using 2 sided tape between the foams, didn't seem to help. A buddy has a set of Deuces Wild that he'll let me try before I buy any more foams, being in the Northeast crawling season is on hold for a bit so I'm in no hurry (time to dig out the snow tires!!) |
01-08-2016, 04:45 PM | #14 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
I use rubber cement to fix the outer foam to the closed cell inner. I also tried the 2 sided tape. Both worked well. The cement is much easier. I just put the foam inner and outer together. Then lifted the outer off the inner and brushed the glue in.
01-12-2016, 08:48 AM | #15 |
I was thinking of venting my tires. I see in the above threads that water incursion has been brought up? I don't do a whole lot of wet crawling, but there are a few little water / creek crossings on my backyard course. How much water incursion can I expect if vent. (3 holes with a small punch as mentioned above) I'm running 2.2 R35 Trepadors. I do not have closed cell foams in them.
01-13-2016, 05:08 PM | #16 | ||
02-10-2016, 08:28 AM | #17 |
Well...I tried using two sided tape between the foams and its a slight improvement. Its almost as though the foam's I have are a bit too small, the tire feels a bit "loose". A buddy has a set of Deuces wild single stage he's gonna let me try before I buy new foams or further modify these. I'm super excited about these tires, they hook up REALLY well, cant wait to see what happens when I get the foams figured out!
02-10-2016, 10:23 AM | #18 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
Single stages are really nice they make an RC tire look like a 1:1 tire, and they can be used for faster purposes. For growlers, I'd've chosen 5.5 tall DD foams. Depending on the weight of the RC, you should end up with soft/front-medium/rear, or medium/front-firm/rear. The whole reason for the different outer foams from front to back is the weight transition to the rear when your RC (wraith) starts climbing. You don't want the rears to fold over from the sight of you RC. I have 1.55 growlers, and 1.9 growlers, and I believe I use the same DD combo in either set of tire, to their respective sizes. As for venting the tire, Do it! The centrifugal force from lifting you RC off the ground and throttle spinning your tires will clean most of the water out of you vented tires, if you vent the rim then that same centrifugal force doesn't allow any water to escape from the inside of the rim/wheel. Last edited by Alexander_0_1; 02-10-2016 at 10:26 AM. |
02-11-2016, 11:13 AM | #19 |
You might be right about the 5.5 version, maybe the ones I'm running are a bit too small, I can see where that would cause symptoms like what I'm having.
02-11-2016, 11:44 AM | #20 | |
Quarry Creeper Join Date: Dec 2013 Location: ][V][
Looking for foam help - Similar Threads | ||||
Deuce's Wild XL Foam Pair; 3.8" ID; Yeti XL Foam / BFG Krawler Tire | Nova's Ark | Crawler Innovations | 12 | 08-31-2015 08:20 AM |
Axials with standard foam Vs Losi with Memory foam - bounce test | Mud Puppy | Tires and Wheels | 3 | 10-24-2010 11:10 AM |
Nova foam vs. Proline 2 stage oversize foam | sbarnesvta | Tires and Wheels | 36 | 05-07-2010 09:04 AM |
do i trim the memory foam like i did the reg foam with the stock tires? | bmuenter | Tires and Wheels | 8 | 08-15-2008 08:59 PM |
