02-16-2016, 12:09 PM | #1 |
Newbie Join Date: Jun 2015 Location: Right their !!!!
| Slw hubs??
Doing a wide xr10 mod to scx10 Axel what slw hub would I need to make the rear as wide as the front, also iam using method wheels.thanks
02-16-2016, 12:20 PM | #2 |
| Re: Slw hubs??
That depends on what hub you have on the front...
02-16-2016, 12:28 PM | #3 |
| Re: Slw hubs??
It will be the stock hub that came with my spawn. Not sure what size that is.
02-16-2016, 12:30 PM | #4 |
RCC Addict Join Date: Aug 2005 Location: SoCal
| Re: Slw hubs??
Are you using a stock rear axle? Then you'd need .225s in the front and .850 in the back.
02-16-2016, 12:30 PM | #5 |
| Re: Slw hubs??
Can't get an answer without all the info.
02-16-2016, 12:45 PM | #6 |
| Re: Slw hubs??
The front Axel will be sxc10 with wide xr10 mod and rear axle will be stock and plan on using the method wheels that came with my spawn .
02-16-2016, 12:46 PM | #7 |
| Re: Slw hubs?? |
02-16-2016, 12:48 PM | #8 |
| Re: Slw hubs??
.225 is that hub that comes stock with axial method wheels.
Slw hubs?? - Similar Threads | ||||
PSA: Vanquish SLW hubs use different screws than Axial SLW hubs | fyrstormer | Tires and Wheels | 2 | 04-29-2015 07:06 PM |
