01-09-2007, 11:52 PM | #1 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Star Pattern Template
I'm lazy and tired lol So I was curious to see if anyone made a printable start template so I can just trace it onto my foams and cut it out. if so can I have a copy please lol hopefully i don't get shot for this post |
01-10-2007, 02:02 AM | #2 |
Quarry Creeper Join Date: Dec 2005 Location: United Kingdom
Yes there is a drawing within the forum. A few presses of your puter keys and I am sure you will find it |
01-10-2007, 04:12 PM | #3 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I will post up pics on how to do it.
01-10-2007, 04:16 PM | #4 | |
RCC Addict Join Date: Dec 2004 Location: Central NY
01-10-2007, 04:19 PM | #5 |
I will do it this evening.
01-10-2007, 04:47 PM | #6 | |
01-10-2007, 04:55 PM | #7 | |
01-10-2007, 05:03 PM | #8 |
Rock Stacker Join Date: Nov 2006 Location: NOVA
I did the search thing last night like everyone is suggesting newbies do. After 40 minutes I gave up, tried to help you out dude. Goodluck, maybe someone will show us how its done. |
01-10-2007, 05:28 PM | #9 | |
I wouldn't be supprised if the reason you didn't find anything last night was because you don't read. | |
01-10-2007, 05:55 PM | #10 |
I measure 1 inch increments around the foam. Then draw a line across the face of the foam. Use a new (sharp) utility knive to cut a V shape between the lines and work your way around the tire. Last edited by dezfan; 01-10-2007 at 06:05 PM. |
01-10-2007, 05:59 PM | #11 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
jolly good show dez. its amazing how hard it can be to cut v-notches out, especially with out a pic to see what a v-notch looks like. |
01-10-2007, 06:00 PM | #12 |
Thanks Dezfan, yours is the explanation I found that I mentioned in an earlier post. Not I just need to tackle it lol.
01-10-2007, 06:34 PM | #13 |
Quarry Creeper Join Date: May 2006 Location: Chandler
You can also use a dremel with a cut off wheel. I found that easier than using a razor blade.
01-10-2007, 06:36 PM | #14 |
Would one of those long knifes work? Like the ones used for cutting bread, but sharper.
01-10-2007, 06:45 PM | #15 | |
/pictures somebody cutting foams with a cleaver. | |
01-10-2007, 07:15 PM | #16 |
I use a handy dandy hot knife. Works great!
01-10-2007, 07:25 PM | #17 | |
01-10-2007, 08:26 PM | #18 |
I use a long fine tooth sawzall blade. Works like a charm. Oh,and if anyone needs to know.....you can buy them at the sawzall blade store |
01-10-2007, 10:27 PM | #19 |
OK Here we go.: Start with a full 2.2 or full size foam. Cut it in half laterally with sharp fabric cutting scissors. We are dong a set for a comp 2.2 here. You will end up with 8 donuts out of 4 full foams. |
01-10-2007, 10:29 PM | #20 |
Next mark the foam at 12, 3, 6, and 9 as on a clock. Second split those marks in half with another 4 marks. Then split those in half again so you end up with 16 marks evenly spaced. Then split those marks laterally so it kind of looks like a spider web. |
