Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Duratrax 1.9/2.2 Scale Tires
Old 03-02-2017, 08:28 PM   #181
Default Re: Duratrax 1.9/2.2 Scale Tires
I figured I would try a set of 1.9 showdowns since they are so cheap. If they run as good as proline's tsl or hyrax these will be my new go to tire.
JBurke187 is offline   Reply With Quote
Old 03-02-2017, 11:38 PM   #182
Good choice ;) Guess you won't be disappointed.
Sent from my SM-G930F using Tapatalk
tjohanne is offline   Reply With Quote
Old 03-10-2017, 04:52 PM   #183
Just ordered a set of 2.2 Showdowns for the Wraith. $38 for 4 tires! At that price, I figured they are definitely worth a try! (C3 compound)
mewalsh100 is offline   Reply With Quote
Old 03-11-2017, 09:45 AM   #184
Has anybody tried the Deepwoods? I heard they are good 2.2s
TROPIX is offline   Reply With Quote
Old 03-11-2017, 10:30 AM   #185
OK I posted before I read the previous comments.So I need another set of wheels and tires has anybody tried the the Showdowns 2.2 premounts ?
Old 03-14-2017, 08:17 AM   #186
Not the pre-mounts, but pictured are my new 2.2 Show Downs (C3). Comparison against Axial BFG's and Trepadors and on the Rig. The compound feels very soft and tacky. I think these tires are going to work out great once they're scrubbed in. You simply cannot beat the price either! I got all 4 for $40!
Old 03-14-2017, 06:45 PM   #187
Those look perfect on the gorgeous Boom Racing Kraits you have them mounted on, and on that rig even with the white lettering facing out!
That thing seems like it can't decide whether to be a rock racer or a rock bouncer... great choice.
durok is offline   Reply With Quote
Old 03-15-2017, 12:08 PM   #188
Thanks! I have a dedicated crawler and a Go Fast rig in my Losi Baja Rey. So, I kinda blurred the lines with the Wraith. That said, it does crawl pretty well!
Old 05-01-2017, 12:44 PM   #189
Huge props to my Duratrax Showdowns!
2nd place yesterday in the 1.9" class at CWRCC G6 event. https://www.facebook.com/events/1119...tab=discussion
I'd like to thank Duratrax for making such an inexpensive great tire.
They grab the rocks, run the loam, & stay clean in the muck.
basic SCX10ii Setup:
Tire: Duratrax Showdown (vented)
Insert: F-Proline CL 2stage , R-stock Duratrax
Wheels: heavy generic Aluminum Bead Locks.
GLwagon is offline   Reply With Quote
Old 05-01-2017, 01:00 PM   #190
Still took the 1st loser position
Rear foams would have helped...
whitrzac is offline   Reply With Quote
Old 05-01-2017, 07:08 PM   #191
I joined the Band!
I put 1.9 Duratrax Scalers on Gmade plastic beadlock wheels and first ran them on my Komodo.
They are significantly taller than the stock tires and I was really happy for the performance. I tested on my backyard rockpile on a day where it drizzled most of the day so the rocks were wet and the tires collected dirt and I was still able to take lines that were nearly impossible with the stock tires.
spaceman5280 is offline   Reply With Quote
Old 05-01-2017, 07:14 PM   #192
I joined the Band!
Next I tried the 1.9 Scalers on my Ascender and they did as well or better than stock.
The extra height helped on some lines that were more difficult with the stock tires.
The rocks were wet and the tires were covered in sand and they still did well.
Old 05-06-2017, 09:54 PM   #193
I was surprised at my truck....to me ..... These Duratrax showdowns worked flawless..... I don't use foams... My tire going flat , bead coming out , a lil....tire got punctured , lil pin size hole.... Tire glue yo the rescue ..... Tires did really well....video from going up a rock ..... https://youtu.be/xOYIXTYCJ7A
Edit......Oh and no foams in the tires....just air
Frank211 is offline   Reply With Quote
Old 05-22-2017, 10:29 PM   #194
https://youtu.be/7uZGAk1zUj4 the trx-4 with Duratrax 1.9s of you haven't seen the video yet.....
Old 06-02-2017, 08:20 AM   #195
So i purchased a set of 1.9s SHOWDOWNS.... Any suggestions on what foams to use...thanks guys
Old 06-05-2017, 01:27 PM   #196
Look what came in my mail today my 1.9 SHOWDOWNS[IMG][/IMG]
So any suggestions for a foam to go inside of these tires...... Thanks guys for all the help... Greatly appreciate it
Old 06-05-2017, 03:22 PM   #197
My personal choice was CI Deuces Wild TSL XL. They fit perfectly. Very happy with that combination.
Old 06-06-2017, 01:51 PM   #198
Here's 1.9 Deepwoods on Gelande II. I had them on a CR01 and they were great. They are very soft and tall for 1.9.
neospirit is offline   Reply With Quote
Old 06-06-2017, 05:11 PM   #199
I love Duratrax Banditos for my on-road buggy. The rubber compound gets gummy as it heats up, and the tires *do* heat up noticeably even on cloudy days when the pavement isn't hot. I'd certainly give their crawler tires a try if I were in the market. Not sure they're the most scale-looking, though.
fyrstormer is offline   Reply With Quote
Old 06-06-2017, 07:46 PM   #200
Painted letters come off easy, and the Scaler models have the Goodyear Wrangler-style sidewalls - I think they deliberately avoided matching tread designs to avoid paying licensing fees.
That way they can pass the savings on to the customer...
Duratrax 1.9/2.2 Scale Tires - Similar Threads
New scale wheels and tires from Duratrax TwistedXT Tires and Wheels 11 07-17-2010 02:20 AM
Axial Scx10 and Duratrax Scale Run ebbet Scale Videos! 3 01-28-2010 09:01 PM
Duratrax Warhead tires mulchman Tires and Wheels 1 03-01-2007 03:29 PM
