Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Duratrax 1.9/2.2 Scale Tires
Old 06-16-2016, 10:47 AM   #61
Natedog's Avatar
Default Re: Duratrax 1.9/2.2 Scale Tires
Agreed.
Old 06-16-2016, 12:21 PM   #62
Natedog's Avatar
These are going to look great on my 1.9 Wrascenderaith!
Old 06-16-2016, 12:49 PM   #63
Originally Posted by crawl-o-matic View Post
That's because they're not a competitor...the other companies I mentioned are though
Your right, you are not even in the same league as they are when it comes to sales.
Ditchrat is offline   Reply With Quote
Old 06-16-2016, 07:02 PM   #64
Jus
Ouch
Still loving these tires the more I look at them. Next time I see a set in person no way am I gonna be able to walk away from them.
Jus is offline   Reply With Quote
Old 06-17-2016, 01:15 PM   #65
Natedog's Avatar
Jus do it! That's how I was too.
Old 06-18-2016, 01:32 PM   #66
Took delivery of a set of 2.2 Showdown earlier today, C3 compound is super soft, feels like my RC4WD Genius tires, and the included inserts are a med-soft density. May not need the Pro-Line 2-stage foams I ordered with them. Tires look good on 1.3" (33mm) and wider wheels, they look more like an inner tube (overly rounded sidewall and tread profile) on the 1" wide SSD steel and knock-off KMC XD795 wheels I have.
The pictures don't do the tires/wheels justice. The wide look much better in person, but the narrow wheels look even more ridiculous. I have a set of 40mm (1.57") wide Hot Racing, black steel D-hole wheels on the way. May order a set of white 8-hole.
Soldat Vaillant is offline   Reply With Quote
Old 06-18-2016, 03:12 PM   #67
Just measured the Showdown on the Locked-Up wheels with the Duratrax inserts and they're 5.95" diameter, not the 5.3" Tower has in their specs. Width is 2.4".
Old 06-18-2016, 05:05 PM   #68
Well that's two R/C crawler companies I won't buy from. First Vanquish and now Ottsix and both for how their representatives have conducted themselves on social media and message boards.
SPLATT is offline   Reply With Quote
Old 06-18-2016, 06:44 PM   #69
Natedog's Avatar
Played with bunch of foams today and settled on CI DW foams for Proline TSLXL, now to find wheels!
Old 06-18-2016, 10:09 PM   #70
cheaper tires... i'd definitely give em a try!!
clodzilla319 is offline   Reply With Quote
Old 06-19-2016, 12:08 AM   #71
Natedog's Avatar
Originally Posted by Soldat Vaillant View Post
Took delivery of a set of 2.2 Showdown earlier today, C3 compound is super soft, feels like my RC4WD Genius tires...Tires look good on 1.3" (33mm) and wider wheels, they look more like an inner tube (overly rounded sidewall and tread profile) on the 1" wide SSD steel and knock-off KMC XD795 wheels I have.
Looks great on the wider wheels, the 1" wheels are lol. Is that first wheel a Gearhead or? Those and the wider black and blue SSDs look great and are good width wheels. Wish SSD would make those in 1.9!
X2
Old 06-19-2016, 04:35 AM   #72
The first wheel is the Trail Ready from Locked-Up with two wheel wideners and their Sever beadlock ring. Bead width is 39.34mm (1.54") with two wideners installed.
Old 06-21-2016, 11:47 AM   #73
Natedog's Avatar
Thanks!
Old 06-25-2016, 05:21 AM   #74
Wow! That's some good looking wheels, think i might get a set of the Approach or Scaler tires.
And the price is insanely good, i can almost get 2 different setups for the price of one setup from the more expensive brands!
Haziza is offline   Reply With Quote
Old 06-25-2016, 06:35 AM   #75
Got the Hot Racing steel wheels in and have a few pictures with the Showdown mounted. The wheels have a 6-lug removable hub, but it's not SLW compatible. I don't like the screws coming in from the back to simulate a lug stud, so I tapped the M2.5 through-holes in the hub for M3 x .5 thread. Tires mounted up pretty easy using long screws and they're shown below with the Pro-Line 2-stage over-sized foams.
Wheels are 40mm total width with a 37mm bead width and have a PVC inner lock ring, the hubs are designed for Wraith 12mm hex adapters. A good steel beadlock for about $50-55 for a full set with hardware and hubs. So the complete set of Duratrax tires and Hot racing beadlocks cost about $100.
Old 06-25-2016, 06:51 AM   #76
snapon boy's Avatar
We need some driving footage
149 r/c worx team driver
snapon boy is offline   Reply With Quote
Old 06-25-2016, 08:44 AM   #77
Just picked up a set of Showdown 2.2's also. Should do great in our mixed PA terrain with the open lugs. Good looking tires, and feels like a nice compound too, we'll see how they do.
Personally, I like the white lettering. Totally facing it out.
OSRC is offline   Reply With Quote
Old 06-26-2016, 04:19 PM   #78
Jus
So I assume the bead is normal and compatible with most beadlock wheels?
So close to ordering a set of 1.9 showdowns for my 1.9 wraith.
Old 06-26-2016, 05:19 PM   #79
Natedog's Avatar
Yes and yes.
Old 06-26-2016, 07:19 PM   #80
As Nate said, yes to both.
Duratrax 1.9/2.2 Scale Tires - Similar Threads
New scale wheels and tires from Duratrax TwistedXT Tires and Wheels 11 07-17-2010 02:20 AM
Axial Scx10 and Duratrax Scale Run ebbet Scale Videos! 3 01-28-2010 09:01 PM
Duratrax Warhead tires mulchman Tires and Wheels 1 03-01-2007 03:29 PM
