Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: How do you install Slw hub on axial 8 hole wheel?
Old 05-04-2016, 03:29 PM   #1
Default How do you install Slw hub on axial 8 hole wheel?
Well the title makes it pretty clear.
How do i install these??
i have axial 8 hole wheels and i got some 350 Vanquish slw hubs, how do i install these?
Bmxreeves is offline   Reply With Quote
Old 05-04-2016, 03:36 PM   #2
Default Re: How do you install Slw hub on axial 8 hole wheel?
You can't. The Axial 8 holes use hexes. You need the newer Axial Method wheels.
mikebecher is offline   Reply With Quote
Old 05-04-2016, 03:39 PM   #3
MODERATOR™
EeePee's Avatar
Read the Sticky at the top of this section.
EeePee is offline   Reply With Quote
Old 05-04-2016, 03:42 PM   #4
Shootz brah, dat one wen go right pass my head.
Old 05-04-2016, 03:46 PM   #5
Dangit man. I called a hobby shop and they said I had to drill out the holes around were the nut goes.
1.9 Ibex tuber
Old 05-06-2016, 04:10 PM   #6
To the people who said it wouldn't work...
1.9 Ibex tuber
Old 05-06-2016, 06:13 PM   #7
Nothing proves your point quite like a picture that doesn't show what you say you're right about.
WHITE-TRASH is online now   Reply With Quote
Old 05-06-2016, 08:55 PM   #8
Maybe he meant, climb three 2x4s with a 1.9. I call BS on both.
SCREAMER is offline   Reply With Quote
Old 05-09-2016, 02:06 PM   #9
"Nothing proves your point quite like a picture that doesn't show what you say you're right about. "
"Maybe he meant, climb three 2x4s with a 1.9. I call BS on both. "
Lol... smart-asses... luv it...
slapjack is offline   Reply With Quote
Old 05-15-2016, 06:15 PM   #10
My stock rtr wheels accepts vp slw hubs ;)
802coma is offline   Reply With Quote
Old 05-15-2016, 07:06 PM   #11
I believe LockedUpRC has the wheel adaptors that will fit those.
Solitaire is offline   Reply With Quote
How do you install Slw hub on axial 8 hole wheel? - Similar Threads
Vanquish SLW Wheel Hub Vs axial stock parts le varan Axial Yeti 12 05-12-2015 11:57 PM
Vanquish SLW wheel hub wheel mounting screws? chevyfan3 Tires and Wheels 6 05-16-2013 04:43 PM
Mounting SLW hub on xr10 wheel dogzpolo Tires and Wheels 6 02-18-2012 09:48 AM
