08-18-2015, 08:40 PM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: Nampa
| JConcepts Scorpios - 2.2" All-Terrain Racer Tires
Are we able to run them at next years Axialfest ?? Is anyone running them right now?
09-06-2015, 11:05 PM | #2 |
| Re: JConcepts Scorpios - 2.2" All-Terrain Racer Tires |
01-06-2016, 03:02 PM | #3 |
Quarry Creeper Join Date: Oct 2010 Location: Rhode Island
Ive looked and have not found any reviews of these. I am intrigued but the size has me unsure. Has anyone given them a try yet? |
01-06-2016, 03:30 PM | #4 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
D-lux is running a pair on his MOA truck for rear tires. Looks like they wear pretty fast by the pictures.
01-24-2016, 01:57 AM | #5 |
Newbie Join Date: May 2014 Location: Hong Kong
Sorry for resurrecting an old thread if it's an old thread, but I'm not sure if I've just come across a defect with my 2.2 Scorpios, or that it's something else. The tires do actually run very well, but only 3 of them fit perfectly on my steel/aluminium beadlocks. The last one could not be locked in the beadlock wheel properly, the lip fits in and can be clamped down with the ring, but is loose enough for the tire to come off by pulling with medium force with my hands. This is not tight enough for trail crawling as the rotation force and grip still pulls the tire out of its beadlock wheel. I've tried it with other 2.2 beadlock wheels (3 different ones), and all of them don't lock the wheel properly. Is there something I'm doing wrong? or is it just a defect? I'll post some pictures if requested. |
02-02-2016, 03:59 PM | #6 |
14jimik1 I have my set on some axial 8 hole 2.2s for now. They mounted up easy, zero problems. |
02-03-2016, 09:32 PM | #7 |
I really like mine. They are huuuge. A little stiff. Stock foams were way too stiff, but work perfect in my Radial baja claws Beads were very uniform and fit SLW wheels perfect. I don't have enough run time to say how they are traction wise, though the 1.9s are a great tire, I've got a lot of time on them.
03-13-2016, 03:25 PM | #8 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
I'm going to try them on my 1/6 Willy's that is a heavy body so stiff foam will be needed.
03-21-2016, 08:10 AM | #9 |
| Re: JConcepts Scorpios - 2.2" All-Terrain Racer Tires Last edited by twissted; 03-21-2016 at 04:34 PM. |
03-21-2016, 09:50 AM | #10 |
Quarry Creeper Join Date: Nov 2013 Location: California
I love the scale tread pattern on that tire. ^^^^ Perfect width too. Is the actual diameter really over 5.5" tall?
03-21-2016, 10:06 AM | #11 |
Don't take offense but those look way better than what you had on there. First impressions on performance?
03-21-2016, 10:07 AM | #12 |
03-21-2016, 12:42 PM | #13 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Scorpios are 6" tall.
03-21-2016, 04:45 PM | #14 |
I think that they will have a lot of bit. They are soft compound and the tread is set up to be that way also. I used the XL 2.2 CI foams because of the tall side wall it will need them so that the wheel doesn't fold in hard turns ad side-hill rock climbing. The tire is larger than the foams and that is a good thing because it lets them shape to the rocks. |
03-21-2016, 04:49 PM | #15 |
03-21-2016, 07:37 PM | #16 |
Newbie Join Date: Mar 2016 Location: behind the iron curtain
Big fan of the 2.2 scorpios here. They work really well on the rocks, fairly responsive in the dirt/faster stuff. The added height isn't so scale but the clearance is nice. CI deuces wild 2.2 talls are not quite tall enough, it leaves a weird excess IMO. The 2 stage (6.0) CI double deuce foams are the sweet spot, they fit and work well.
03-22-2016, 08:57 PM | #17 |
Quarry Creeper Join Date: Dec 2015 Location: United States
That size is a great fit on your 1/6 Willy's. I like these tires and J-Concepts in general, but they're too tall for anything I have. if they were to release a 5.25-5.5 I'd be one of the first to buy a set.
03-22-2016, 10:02 PM | #18 |
07-03-2016, 09:34 PM | #19 |
Rock Crawler Join Date: Dec 2013 Location: Norway
JConcepts Scorpios - 2.2" All-Terrain Racer Tires - Similar Threads | ||||
JConcepts Scorpios ! | CKRC Hobbies | CKRC Hobbies | 0 | 04-21-2015 05:05 PM |
thoughts on JConcepts Rocx 2.2" Rock Crawler tires | stankulas | Axial XR10 | 4 | 11-30-2013 12:01 PM |
Flat Iron 2.2" M3 (Soft) Rock Terrain Truck Tires | bigal53021 | Tires and Wheels | 2 | 09-19-2010 08:27 PM |
