Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: cant find hex hubs
Old 08-22-2016, 07:18 PM   #1
Default cant find hex hubs
so i bought some rc4wd ones and there to small so here is pics of the rim and size to the outside of the holes i want some 12mm hex hubs for it over the pin style hub i have
ben h is offline   Reply With Quote
Old 08-22-2016, 07:33 PM   #2
Default Re: cant find hex hubs
After the hex drive hubs come loose on you for the 5th time in the last 2 batteries you'll wish you still had pin drive hubs.
WHITE-TRASH is offline   Reply With Quote
Old 08-22-2016, 08:40 PM   #3
iv never had an issue on any other tire setups with them and these pin ones dont agree with my wraith axles or i wouldnt care
Old 08-22-2016, 09:34 PM   #4
don't agree??? very descriptive
unfortunately rc4wd bolt pattern does not match anything else
find out what the disagreement is between them or get new wheels
if it is a question of offset rc4wd has deeper hubs
cabron is offline   Reply With Quote
Old 08-23-2016, 07:38 PM   #5
rc4wd hubs are to small for this bolt pattern
and been awile since i put em on i think the pins arnt far enough away from the tubes and the wheels bind on the tubes
Old 08-23-2016, 08:24 PM   #6
is something keeping the outer knuckle bearing from seating all the way in?
or the inner knuckle bearing from seating in well?
do all 4 wheels do the same?
Old 08-23-2016, 08:45 PM   #7
You can drill those wheel bolt holes out with a 1/8" drill bit and use VP SLW hubs. At least I did on some Pro10's years ago.
Edit for link.
Szczerba's IFS SCX Build
Szczerba is online now   Reply With Quote
Old 08-23-2016, 11:06 PM   #8
Edit for link.
dont them hubs have the same bolt pattern as the rc4wd wheels?
Old 08-24-2016, 11:25 AM   #9
Natedog's Avatar
IME RC4WD, HR and VP hubs are all close enough that running a drillbit through the hub holes in the wheel is usualy all it takes to swap hubs between these wheels.
Old 08-24-2016, 06:20 PM   #10
oh ok yea these are a bit bigger then them put one bolt in and the bolt on the other side is in the big center hole
Old 09-25-2016, 05:51 AM   #11
Am using the RC4wd pin hub Wagons on an Ascender and had to put 2 thin 5mm washers between the pin and the bearing to get them to snug up without end-play. Working fine so far without any rubbing.
anuthabubba is offline   Reply With Quote
cant find hex hubs - Similar Threads
Where do I find gmade 12mm to 14mm hex adaptors? scoobyblue G-Made Crawlers 4 04-14-2012 11:40 PM
N E 1 where I can find a 1.3mm ground or machined hex driver ? Joat Tools, and Procedures 1 02-22-2009 07:30 AM
help me find wheel 2.2 17mm hex 1/2 offset buju Tires and Wheels 6 10-09-2008 02:20 PM
