12-24-2016, 04:08 PM | #1 |
| Homemade tire foams...?
I haven't tried it yet but I am going to order one. But has anyone considered using a large pool noodle to make firm foams. These have a 4.5" OD and would work for some tires and not all. At $15 a noodle I'm thinking it's worth a shot. Even if it's a bust I can use the noodle in my pool. Gnome saying. Mighty Pool Noodle | CanUdle.com I've got various CI Foams in 1.9 and 2", and they're fantastic. But I've happened across 4 sets of 2.2s recently and was going to give this a try. |
12-30-2016, 04:45 PM | #2 |
My noodle showed up today. So I dug out a Deuce's Wild single stage to compare. I really like these CI DW SS foams but they're not wide enough and are loose on the wheel, IMO. To get them all the same the best and easiest way was to use a CD case. So off to the storage boxes to find my old CDs. I measured the CI foams and added 5mm to the width. Stacked CDs in the lid and made my cut with a regular hobby knife. Then trimmed a bevel so that the tires would seat. I wanted to use these glue on RPM wheels. Sweet. Found some classics to reminisce, too. Made a cut and compared numbers. The ID of the CI is basically 2.25". The noodle is 2". Gudintight. The OD of the CI is 4.75" vs 4.5" of the noodle. The bevel is hard to see on the noodle foam. I left the noodle foam flat for now. I'd rather have the tire more filled out and slightly pull the tread down. Excuse the crappy iPhone pics but the light was fading. Now these are as firm or firmer than the single stage foams. I am happy with them for my 5 minute run around the yard as it was getting dark. I'm going to try to get them to a rock pile somewhere to check out for crawling. But the purpose of this rig is for trailing. I have a dedicated crawler chassis on CI Double Deuce Comp Cuts with medium outers and they're hands down fantastic. So for less than $15 I've got a set of trail/bashing foams and should be enough to cut another complete set out of for a second Wraith I'm working on...if not a third set. Last edited by Brake Weight; 12-30-2016 at 04:47 PM. |
01-02-2017, 10:24 AM | #3 |
| Re: Homemade tire foams...?
I took the Bomber to some rocks this morning. We've had an insane amount of rain lately and I normally don't do wet wheeling but did today. The Bomber performed as well as could be expected from a stock Bomber. The foams are too firm to consider any decent rock crawling but I think dirt piles and general trail bashing will be great. |
01-04-2017, 12:02 PM | #4 |
I'm cooking on an idea. If I can come up with a jig to mount on my drill press and cut the noodle at say, 3.5" OD. Then cut a stock foam at 3 or 3.25" ID and 'friction' mount it on the noodle. |
01-04-2017, 03:05 PM | #5 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
I like where your going here! Keep at it.
01-08-2017, 07:35 AM | #6 |
Newbie Join Date: Jan 2007 Location: harper ferry
I too am thinking pool noodle.I can't wait to see how this turns out !!
02-03-2017, 11:16 AM | #7 |
I bought several sets of cheap factory foams to hopefully cut up for this project. It's been on the 'backburner' for a while for life to take precedence.
04-10-2017, 10:06 AM | #8 |
Aight kids, gather around. I got bored today and decided to mount a set of Falken Wildpeak MTs for my Wraith. I had recently bought a big box of used factory foams and rummaged through it. One set were really soft and those I used. I measured the width of the Axial beadlocks and marked my pool noodle at 40mm. This'll make the tire bulge ever so slightly once mounted. I figured out a better way to cut the noodle. Wrap it with a thick cardstock type material and tape it down level. Just like a welder wrapping a large pipe to mark it for a cut. Then use a large knife and roll it away from you. This will 'pull' the blade across the noodle in a natural cutting motion. Also line the blade up against the edge of a table or counter...deep freezer in my case. Next I mounted the noodle onto a wheel and marked off 15mm from where the bead will seat. A few marks will make a line once spinning on the drill press. I tried to make a single pass cut using my knife and it's a bad idea. The blade hung up and I ended up destroying a foam and my finger against the chuck. So I got a fresh blade in my hobby knife and cut sections out one at a time. There is quite a bit of difference in the OD of the noodle and ID of the soft foam. I tried to cut the soft foam and it didn't want to cut cleanly. I did not push it any further as I only had four of these and did not want one torn in half. Here's where I apologize and offer a disclaimer. I was so eager to get them all mounted I didn't take any further pictures. But the outer foam was a tight fit and once centered on the noodle it was fine. I found it easier to put the noodle on the beadlock barrel and then the soft foam onto the noodle. Then the entire assembly into the tire. I'll post pics if and when I break a wheels down again. Disclaimer: if you attempt this and end up bleeding out like I did, it's your own fault and not mine. You are hereby warned of the hazards of rotating equipment and sharp objects. Glasses, gloves, and anything else you'd need. Last edited by Brake Weight; 04-10-2017 at 10:15 AM. |
04-10-2017, 10:12 AM | #9 |
Here's a Deuces Wild dual stage foam with me pressing on it. My homemade dual stage foam and the same amount of pressure. Looks like I should've gone a few more MM larger. |
04-10-2017, 10:32 AM | #10 |
You convinced me ! Just ordered another 2 sets from Eddie . No cutting, bleeding, drill press, just proper working foams the first time for me. Hang up and Drive |
04-10-2017, 10:40 AM | #11 |
Somebody had to do it.
04-10-2017, 10:42 AM | #12 | |
| Re: Homemade tire foams...? Quote:
I've thought about this, but never found a noodle the right size. I'm glad you're trying something different. In my opinion we have good foams, but I honestly don't think we've found the "best" solution yet. | |
04-10-2017, 10:56 AM | #13 |
Thanks for the comments. I'm just trying to get the idea out there. There will always be somebody else to take it to the next level. I just hit a rock pile on the way to preschool pickup. I definitely need some forward weight to climb a few obstacles and this is the tire under the weight of the Wraith only. |
04-10-2017, 11:12 AM | #14 | |
Remember, Axial compound isn't the best. And I've heard those Falkens are stiff unless you sipe them. | |
04-10-2017, 11:59 AM | #15 |
| Re: Homemade tire foams...? |
04-10-2017, 12:23 PM | #16 |
04-10-2017, 12:42 PM | #17 | |
Tire advancement moves faster than cellphones. No sense in me trying to keep up since I don't comp. I still use my old iPhone 5 and I'd rock some Co-Ops or Buckshots on my 1:1 if they were available when the time comes. | |
04-10-2017, 12:59 PM | #18 |
I just trimmed up some Moabs... I don't keep up either! I like this thread, keep experimenting and posting. Not everyone has the funds to always buy the answers. (And sometimes it's more fun to make them anyway!) On a side note, I did dremel up my Falkens, and they are a ton better. Just cut the bars in 1/2 and they came alive. |
04-10-2017, 01:07 PM | #19 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Ernie | |
04-10-2017, 01:38 PM | #20 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
Having made custom traveling bags for my electronic testing gear, I'd recommend taking a trip to a local foam shop to see what they have to choose from; they may have some scraps that you can play with, and some tips on how to cut the stuff. The pool noodle foam seems to me to be on the stiff side for an off-road rc. Rather than pressing on them, use a standard weight and ruler for comparing the durometer of the foams and the assembled tires, if just for your own purposes, as a more objective measure. I may have to try this on my 2.8" wheels, as there are basically no optional foams for them. |
Homemade tire foams...? - Similar Threads | ||||
tire foams | traxxasemaxxer | Tires and Wheels | 4 | 10-16-2012 07:24 PM |
Homemade foams for 2.2 Swampers | BigSki | Tires and Wheels | 5 | 07-10-2012 07:45 PM |
Tire foams | team savage | Newbie General | 1 | 02-24-2010 08:00 PM |
Homemade Foam Crawling Tire....say what? | Offroader5 | Videos! | 7 | 12-27-2008 08:16 AM |
