04-03-2017, 09:39 PM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Need foams advice for KLR gold.
So I tried running the Ottsix foams in Toyzuki SCX.2. This weekend I learned the foams are way to stiff. A few friends recommend sanding the ribs off the inside of the tires. This is something I've never had to do with any tire before. Is there a correct foam setup I can use? I was thinking CI dual stage softs? Anyone with a lighter SCX running KLRs have advice? Sent from my Pixel XL using Tapatalk |
04-03-2017, 09:43 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: Need foams advice for KLR gold.
CI makes foams for them no problem. I run soft in the front and medium in the rear and yes 2 stage for sure. Get the comp cut inner and you will be very happy with your performance.
04-03-2017, 09:46 PM | #3 |
So sand the ribs off the inside? Sent from my Pixel XL using Tapatalk |
04-03-2017, 10:33 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
No need to modify the tires. Just CI foams as suggested by Billy D in the 4.25 size
04-04-2017, 08:18 PM | #5 |
RCC Addict Join Date: Aug 2005 Location: SoCal
I liked the voodoo foams the best in the KLRs when I ran them. But the 4.25 comp cut CI foams will also work. |
04-04-2017, 08:38 PM | #6 |
The best foams for the KLR are found in other tires...
04-04-2017, 09:20 PM | #7 |
| Re: Need foams advice for KLR gold. |
04-04-2017, 10:00 PM | #8 | |
| Re: Need foams advice for KLR gold. Quote:
How heavy is your truck? The pic above doesn't really show a whole lot. I'd be more interested in what the tire looked like from the other side or the lower tires. The KLR foams I have are significantly softer than the 4.25 CI foams I had. | |
