Proline Hyrax 2.2 Question i have the hyrax 2.2“ and i like them. they are very sticky on the rocks, which is fine on the surface. but the tire sidewall hangs on rocks. is this something i could change with different foams? And which foam shall i use instead of the foams that came with. CI DW (size?) CI DD (size? soft med?) or what else. i'm a little lost here. Rig is an AX10 Scorpion (little Betty :) ) round 5lbs, UD Gears rear and standard front, tires vented. Main propose is crawling. appreciate your help. |
Re: Proline Hyrax 2.2 Question 6" CI foams, usually a stiffer outer for the rear. DD type. Shave your sidewalls... Contact CI directly, they can assist more, weight of rig decides stiffness of foams, maybe softs up front, mediums rear. |
Re: Proline Hyrax 2.2 Question Quote:
Do you mean sanding the treat pattern on the side down? I mentioned looking at it, it's more hanging where no treat pattern is on the sidewall. |
Re: Proline Hyrax 2.2 Question I went with the ProLine dual stage foams. They're made for those tires... |
Re: Proline Hyrax 2.2 Question 6" dual stage soft front, medium rear. I have the same tires on the same weight rig. The tires are alright, I'd say they are better for general bashing than crawling but that opinion may change as I thrash on them more. |
https://www.prolineracing.com/foam/2...-foam-inserts/ maybe i give them a try. will they fit with the stock kit beadlocks of the ax10 scorpion? |
Re: Proline Hyrax 2.2 Question The Proline dual stage foams in the 2.2 size are a little too big IMO. The inners are wider than CI so they dont shift around on the inner wheel ring which is nice. The best combo I found was using the Proline inner and CI DD outer (5.5"), but that means buying 2 sets of foams. |
Re: Proline Hyrax 2.2 Question Thx all. "thumbsup" I will give the proline foams a try 8). so i can compare them with the ci dd 6.0 i have for my little monster. |
Re: Proline Hyrax 2.2 Question I run hyrax2.2 with dual stage proline foams on SSD wheels with proline rings. Unfortunately with stock one piece foam Bomber was better on crawling than dual foam. I don’t know if proline ring of wheel is the reason,but dual foams are very big and pressed the tires with difficulty. Now I ll get new wheels ssd (not for proline this time) to test them |
Internal rings are not going to make any difference to the foams fitting or foams being too big. |
