What foams to get for the rc4wd 1.9 super swampers? Hello, I have these tires: https://www.amainhobbies.com/rc4wd-i...90875?v=204053 What are the best performance single stage foams that fit those tires? My rig is heavy, it’s around 10lbs and i think that some single stage foams would increase it’s performance... Thanks!!! |
Re: What foams to get for the rc4wd 1.9 super swampers? I'd recommend you check out the Deuces Wild foams by crawler innovations |
Re: What foams to get for the rc4wd 1.9 super swampers? Depending on the width of your wheel, you might want to get the proline single stage foams. For method 1.2 wide wheels, i changed from CI to Proline cause the CI foam didnt fill the tire out completly with that wide wheel. EDIT: That was with Proline tires, but im guessing it woud be the same with rc4wd tires. |
