08-12-2017, 10:15 AM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: West Orange
| Voodoo tires
I just found out that the 1.9 voodoo is "highly recommended" to run their Sub 10/+10 2 stage foams. I had purchased the CI two-stage comp foams. OTTOSIX explain to me that there Voodoo Tire has sidewall support and that the foams that I had where design for tires without sidewall support. I ordered thier foams as recommended. While I waited I went ahead installed the CI and broken the tires in till the lugs feathered a bit. Went on the trail. Big difference over stock trx-4. Yesterday my OTTOSIX foams came in and went back to the same trail with identical conditions. I saw the biggest difference on off camber approaches. Down regular trail and straight up little difference. Go sideways....big difference. Now do you guys run your lugs; all 4 point forward all 4 point backwards front forward/rear backwards front backwards/rear forward |
08-12-2017, 10:31 AM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: Voodoo tires
All 4 facing the same direction. Either way is prefernce but yes all the same direction.
08-12-2017, 04:44 PM | #3 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: Voodoo tires
Run mine pointing forward on my basher. I believe it's actually the proper direction. I see people run em in all different directions though. Most times I say something about it and they go....oops, didn't notice I did that. Did you buy yours in the softer crawler compound?
08-12-2017, 07:26 PM | #4 |
| Re: Voodoo tires
I got mine in blue compound. I feel that running them backwards they might climb better.
08-14-2017, 10:56 AM | #5 |
| Re: Voodoo tires
There only one way to find out, try em both ways and report back
Voodoo tires - Similar Threads | ||||
VOODOO 2.2 U4 Tires | CKRC Hobbies | Axial Yeti | 0 | 08-12-2014 11:19 PM |
