Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: 2.2 Classic Alcoa Dually wheels, internal beadlock
Old 08-24-2017, 06:16 PM   #1
Default 2.2 Classic Alcoa Dually wheels, internal beadlock
Well, I'm working on a new tow rig, and always love the look of the shaved classic Alcoa semi wheels, so I downloaded Fusion 360 and made my own.
Built them to use SLW hubs, and made them a bit narrower (30mm) since I'm stretching 1.9 Axial BFG All-Terrains over them.
Well, they came in the mail today, just under a 2 week turnaround time from shapeways, went with the strong and flexible, polished option.
I have 4-40 acorn wheel studs on the way from LockedUp, which 2 of per wheel will hold the center caps on.
-Derek
SuperDrty is offline   Reply With Quote
Old 08-27-2017, 03:58 AM   #2
Default Re: 2.2 Classic Alcoa Dually wheels, internal beadlock
Brilliant idea with the center retention.
wingnutcrawler is offline   Reply With Quote
Old 08-27-2017, 09:28 PM   #3
LockedUp hardware came in over the weekend
-Derek
Old 10-08-2017, 04:18 PM   #4
Dayum!!! Those are sweet. Nice job!
Ben
Itali83 is offline   Reply With Quote
Old 10-09-2017, 04:54 PM   #5
Nice work!
I had a friend draw up and print some 2.2 semi truck wheels for my cxt build.
Szczerba's Build #60, 5th CXT
You may want to reduce the thickness on the bead to have the wheel sit flush with the tire bead. Learned that on our first test print set and reduced it on the final print.
Szczerba is offline   Reply With Quote
Old 10-11-2017, 10:27 PM   #6
Originally Posted by Szczerba View Post
Nice work!
Thanks! I went a little thick on the bead on purpose, but mainly because I wasn't sure of the strength of the print.
Build #60 is looking good!
Old 10-11-2017, 10:37 PM   #7
Here's how the wheels turned out, just painted them black for now, but the truck made it to Crawlapalooza 2017!
-Derek
2.2 Classic Alcoa Dually wheels, internal beadlock - Similar Threads
Internal Beadlock Wheels raceeng18 Tires and Wheels 4 02-24-2012 03:45 PM
