10-06-2017, 01:23 PM | #1 |
Newbie Join Date: Mar 2017 Location: Mountain Home
| Tired weight recommendations
Anybody got an idea on a maximum recommended weight per wheel? I'm trying to offset the weight of my battery and that comes to roughly an ounce per wheel, is that too heavy per axle? Sent from my HTC One using Tapatalk |
10-06-2017, 01:46 PM | #2 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Tired weight recommendations
Generally speaking you don't want the weight to be rotating, lead weights on the inside of the wheel for example, as this rotating mass puts a ton of extra strain on the driveline components. Solid weight, such as brass knuckles, are a preferred option. In terms of how much weight is too much, that really just depends on your truck and how much you need to compensate for a high center of gravity. There's only so much you can do before you simply run out of room or placement options.
10-06-2017, 01:55 PM | #3 | |
| Re: Tired weight recommendations Quote:
Sent from my HTC One using Tapatalk | |
10-06-2017, 02:11 PM | #4 |
Tired weight for a tired question. What vehicle are you talking about? |
10-06-2017, 02:15 PM | #5 | |
They help. Stamped steel wheels, such as SSD D-Hole are a hair heavier. I’d try those and go from there. | |
10-06-2017, 02:19 PM | #6 |
| Re: Tired weight recommendations |
Tired weight recommendations - Similar Threads | ||||
wheel weight vs knuckle or axle weight vs creative weight distribution | tech712 | Axial SCX-10 | 16 | 11-04-2014 01:04 PM |
Recommendations for light weight comp chassis for AX10. | patrol_maverick | Axial AX-10 Scorpion | 18 | 02-04-2014 01:30 AM |
Wheel weight vs. chassis weight ratio OR spung/unsprung bias | solomon7 | Tires and Wheels | 15 | 08-02-2008 06:26 PM |
Tired | BrockGrimes | Tires and Wheels | 2 | 02-25-2006 07:15 AM |
