Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Using a light bulb to remove glued on rc tires from the wheels
Old 01-09-2019, 02:42 PM   #21
Default Re: Using a light bulb to remove glued on rc tires from the wheels
I've had good results with boiling the tires.
Sent from my SM-G965U using Tapatalk
ADlBOO is offline   Reply With Quote
Old 01-09-2019, 03:26 PM   #22
Originally Posted by nightcrawler48 View Post
The tires and rims I want to separate are Axial from the SCX10ii 2017 Jeep Wrangler Unlimited CRC RTR. Just wanted to know if I can expect the same problems with these?
Watch this video he explains how he unmounted Axial RTR wheels from the tire.
https://m.youtube.com/watch?v=iOVxXO...&t=18s&index=4
team green is offline   Reply With Quote
Old 01-09-2019, 03:30 PM   #23
~THE SCALE SHOP~
lol OP and harley trucks were glued on with 2 drops of elmers glue from axial.
aint no way this would ever work on a real consumer glued tire.
STANG KILLA SS is offline   Reply With Quote
Old 01-09-2019, 03:44 PM   #24
I only suggested he watch the video cause he was asking about unmounting a Axial RTR wheel.
I personally use acetone in a sealed Tupperware container and let it sit for 12 hours. With excellent results but your inserts will be garbage
Old 01-09-2019, 05:42 PM   #25
I just had awesome success boiling the Canyon Trails off the RTR TR-X wheels. About 25 mins boiling and they popped right off. Super clean and very little glue residue left on the tires.
mewalsh100 is offline   Reply With Quote
Old 01-12-2019, 10:34 PM   #26
Thanks everyone for your input. I was looking to remove the tires from the rims and reuse the tires. Based on the info you have provided I'm leaning toward leaving the tires on the wheels and just getting new tires to bolt on the beadlock wheels I have. I can probably sell the tires and wheels complete and pay for the new tires with what I get for them. Thought of that first and should have gone that way at the start.
nightcrawler48 is offline   Reply With Quote
Old 01-13-2019, 03:03 AM   #27
I've sure ruined some tires using the toaster oven method! I've never seen this, but am sure excited to give it a try!
coffeeaddict17 is offline   Reply With Quote
Old 01-14-2019, 05:44 AM   #28
I'm new to rc so I never tried it. But ca glue bebonder doesn't work??
floydtn is offline   Reply With Quote
Old 01-28-2019, 02:15 PM   #29
Very nice tip. Thank you.
4kids crawlin is offline   Reply With Quote
Old 02-22-2020, 09:15 PM   #30
Used this method tonight, worked like a charm! Hardest part for me was finding a regular 60 watt bulb in my house. I do have a tiny bit of leftover glue on the tire, but nothing I’m concerned with. Thanks for the tip.
Cocamper is offline   Reply With Quote
Using a light bulb to remove glued on rc tires from the wheels - Similar Threads
How-To: Remove a glued tire pantablo Tires and Wheels 13 12-13-2009 01:59 AM
Best way to remove glued tires from wheels ?? 51WillysJeep Tires and Wheels 22 03-16-2008 03:46 PM
Can I remove glued tires without ripping them? AYKBOBCAT Tires and Wheels 3 03-05-2006 09:21 AM
Tips on ways to remove glued tires from rims? TimsXJ Tires and Wheels 4 09-07-2004 06:01 PM
