Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: 8 Hole Shooters With OMF Rings...
Old 12-08-2017, 09:36 PM   #1
Default 8 Hole Shooters With OMF Rings...
I was wondering if anyone has had any experience with vanquish rings on the Axial 1.9 8 hole shooters. Pictures welcomed.
ThatJeeper2017 is offline   Reply With Quote
Old 12-09-2017, 07:31 AM   #2
Default Re: 8 Hole Shooters With OMF Rings...
The hole pattern on the Vanquish rings doesn't line up on Axial wheels.
svt923 is offline   Reply With Quote
Old 12-09-2017, 02:10 PM   #3
Hmmm. Odd. I keep seeing 8 holes with aftermarket aluminum rings.
Old 12-09-2017, 02:38 PM   #4
You're probably seeing either Chanquish wheels or Locked Up RC Iconics with different rings. Locked Up RC has a bunch of different rings that fit their Iconics which are 8 holes.... 1.9" Iconic SLWC Beadlock Wheel
The Chanquish wheels now also have a few different rings that fit their 8 hole design. I have a few sets.
ElChupacabra is offline   Reply With Quote
Old 12-09-2017, 03:08 PM   #5
Locked up advertises that their rings work with axial...
lonleycreeper is offline   Reply With Quote
Old 12-09-2017, 05:19 PM   #6
I've ran there rings on axial 8 hole. They do fit. They have a different bolt patten than vanquish wheels. I ran into that when I was trying to run there rings on methods. The do make a few for vanquish but most are there bolt pattern which is the same as axial. It's kinda a pain bc the super short bolts you have to use on axial that are not mounting bolts sometimes don't want to screw in so you have to try a few bolts. It's the way the bolts are made I think.
AWraith build is offline   Reply With Quote
Old 12-09-2017, 05:33 PM   #7
I’m positive that they are Axials because of the fake bolts around the wheel nut.
Old 12-09-2017, 05:39 PM   #8
Pictures would help identify things....
Old 12-09-2017, 05:58 PM   #9
Gearhead makes rings for Axial 1.9's. Not aluminum though, Delrin I believe. Not sure if that is helpful or even relevant, just throwing it out there.
OSRC is offline   Reply With Quote
Old 12-09-2017, 06:18 PM   #10
Locked up rings use the same bolt pattern as Axial wheels, there are a few others but I can't remember who makes them.
Old 12-09-2017, 09:39 PM   #11
Mthead makes all kinds of Delrin rings
aztitan is offline   Reply With Quote
8 Hole Shooters With OMF Rings... - Similar Threads
Do VP OMF rings fit Axial 8 hole beadlocks? snicklefritz Tires and Wheels 5 05-19-2015 03:05 PM
