04-11-2018, 12:12 AM | #1 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| SSD hubs with rotors?
Looking for widening my Wraiths front track a bit for better link & shock clearance and add some scale goodness while I'm at it. Will this set (+3 offset) add 3mm each side compared to stock 6 bolt hubs that came with the Spawn kit Method beadlocks? |
04-11-2018, 12:52 AM | #2 |
| Re: SSD hubs with rotors?
The +3mm hubs are about the same as a .350" SLW hub, which I believe is about the same as the stock plastic hubs on the Wraith. That being said, the +6mm are close to a .475" and are probably the best bet for what you're looking for.
04-11-2018, 02:20 AM | #3 |
Thanks. I hate these +offset designations. Give me the hex to wheel thickness in mm or at least in and I'll know what I get! edit: for some reason on RCmart the +6 ones are listed under TRX4 but in the description it says they fit Axial hexes. That and amain are the only options I have with reasonable shipping and amain is out of stock. Last edited by Ninomaniac; 04-11-2018 at 02:50 AM. |
SSD hubs with rotors? - Similar Threads | ||||
New SSD Wheels Hubs with Brake Rotors | SSD | Tires and Wheels | 31 | 07-07-2018 04:44 PM |
SSD Wheel Hubs with Brake Rotors - In Stock! | RPP Hobby | RPP Hobby | 0 | 08-08-2017 12:58 PM |
Check out this little gem of info: Rotors/ hubs for slw wheels | CarterFab | Tires and Wheels | 0 | 01-26-2013 12:20 PM |
