04-30-2018, 04:46 PM | #1 |
| DIY half-assed dual-stage foams
This example used 1" wide cheap 2.2"wheels and 4.5" tall RC4WD Dune T/A trophy truck tires, they will be used on hardpack and possibly a little pavement. The concept should be workable for many other applications, however. Take one 11/16ths-inch wide beadlock inner ring and a roll of 5/8ths-inch wide weatherstripping, wrap the ring with the self-adhesive closed-cell black foam weatherstripping and CA-glue the ends together. Then insert into low-profile tire with relatively soft stock foam and clamp front and rear beadlock wheel faces together. Presto, half-assed dual-stage foams! This idea really only works for either lower-profile sidewall tires or smaller than most diameter wheels and tires because you can't build up enough of a stiffer inside section with weatherstripping to make a noticeable difference in a large volume tire. I'd imagine it'd work great in many 1.55", 1.7", and small diameter 1.9" tires, however. If you can't afford or find real dual-stage or stiffer single-stage foams, using weatherstripping foam as the first layer will still allow you some additional firmness in the center of the tread. If you found thicker and/or wider weatherstripping foam, you could make a more functional setup, especially if you have a wider wheel - this would help more for sidehilling and turning at speed. I did this because the stock RC4WD foams were very soft, and I was using very narrow wheels - wanted to get just a bit more stiffness without going the extra mile of buying aftermarket foams. Every little bit counts! |
04-30-2018, 06:05 PM | #2 |
| Re: DIY half-assed dual-stage foams |
04-30-2018, 07:02 PM | #3 | |
| Re: DIY half-assed dual-stage foams Quote: The closed-cell EPDM sponge rubber used in weatherstripping is extremely dense and has rebound. I have been eyeing my roll of it for many months, waiting for a wheel/tireset where it would come in handy. https://www.summitracing.com/parts/m...MaAvJ6EALw_wcB | |
04-30-2018, 07:09 PM | #4 | |
Yes it is. It’s so dense that it seems to me that it would be almost like running a larger wheel with a recessed bead. (Makes sense in my head) I like where you’re possibly going with it though. | |
11-22-2020, 01:32 PM | #5 |
Installed on my TRX-4: After some running in: Mud scrubbed off by running on pavement with a dusting of sand: |
11-22-2020, 01:49 PM | #6 |
I tried that my issue was when they got wet they lost there stick and end up floating around inside the tire
DIY half-assed dual-stage foams - Similar Threads | ||||
6.0 CI dual stage foams in ripsaws | evan03 | Tires and Wheels | 21 | 11-01-2013 11:33 PM |
New 2.2 and 1.9 dual stage foams | Nova's Ark | Tires and Wheels | 24 | 10-20-2009 07:53 AM |
